[Qgis-user] Problems with Plugins
Nicolas Devaux
nicolas.devaux at supagro.fr
Tue Feb 10 08:51:47 PST 2026
Hi Andrea, you will find the original error message that starts all my
troubles. I can use internet et acces to the plugin server without any
problem. As nothing I tried enhence my situation, I'll uninstall Qgis
and remove all profile and regit information linked to Qgis.
I just want to be able to re install Qgis properly to be able tu install
any plugins, that is not the case at the moment...
Thanks for your tips and advices if you have
Impossible de charger l'extension 'timeseriesviewerplugin' provoque une
erreur lors de l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'colorama'
File "C:\PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python\qgis\utils.py",
line 478, in _startPlugin
plugins[packageName] = package.classFactory(iface)
File
"C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\timeseriesviewerplugin\__init__.py",
line 37, in classFactory
from eotimeseriesviewer.eotimeseriesviewerplugin import
EOTimeSeriesViewerPlugin
line 1100, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\__init__.py",
line 25, in
from eotimeseriesviewer.qgispluginsupport.qps.pyqtgraph.pyqtgraph
import PlotDataItem
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\__init__.py",
line 137, in
from .colormap import *
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\colormap.py",
line 6, in
from .functions import clip_array, clip_scalar, colorDistance, eq,
mkColor
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\functions.py",
line 19, in
from . import Qt, debug, getConfigOption, reload
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\debug.py",
line 28, in
from .util import cprint
File
"C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\util\cprint.py",
line 6, in
from colorama.win32 import windll
Version de Python :3.12.11 (main, Jun 17 2025, 13:41:12) [MSC v.1943 64
bit (AMD64)]
Version de QGIS :3.40.10-Bratislava Bratislava, c98da2e682
Chemin Python :
* C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\eMapTools
* C:/PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python
* C:/Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python
* C:/Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
* C:/PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python/plugins
* C:\PROGRA~1\QGIS34~1.10\apps\grass\grass84\etc\python
* C:\Users\devaux\Documents
* C:\Program Files\QGIS 3.40.10\bin\python312.zip
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\DLLs
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\win32
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\win32\lib
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\Pythonwin
* C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\assets\external\xmltodict-0.13.0-py2.py3-none-any.whl
* C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\assets\external\aenum-3.1.11-py3-none-any.whl
* C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BioDispersal
* C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BioDispersal\qgis_lib_mc
* C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\setuptools\_vendor
* C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\HCMGIS/forms
* C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin
Le 10/02/2026 à 17:42, Andrea Giudiceandrea via QGIS-User a écrit :
> Hi Nicolas,
> which QGIS version are you using exactly? On which operative system?
> What is the URL and the status of the plugin repositories listed in
> Plugins -> Manage and Install Plugins -> Settings? What happens if you
> click on "Reload repository"? What happens if you browse the
> repository URL using a web browser in the same system? Is QGIS,
> installed in your system, able to connect to any Internet resource
> (e.g. the OpenStreetMap XYZ Tiles server?
> Regards.
> Andrea
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Nicolas DEVAUX
Laboratoire d'étude des Interactions entre Sol, Agrosystème et Hydrosystème
UMR LISAH Montpellier SupAgro-INRA-IRD
Bat. 24
place Viala
34060 Montpellier cedex 1
tél : +33 0(4) 99 61 25 45
fax: +33 0(4) 67 63 26 14
email:nicolas.devaux at supagro.fr
http://www.supagro.fr/web/
http://www.umr-lisah.fr/
Je soutiens les contractuels dans leur combat pour une rémunération équitable
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260210/11fe43d4/attachment.htm>
More information about the QGIS-User
