[Qgis-user] Problems with Plugins
Andreas Janz
andreas.janz at geo.hu-berlin.de
Wed Feb 11 01:06:21 PST 2026
Hi Nicolas,
the/EO Time Series Viewer Plugin/ is developed by my colleague Benjamin
(CC). The plugin is using the /PyQtGraph /package, which recently
introduced the *'colorama'* dependency. This explains your error:
*ModuleNotFoundError: No module named 'colorama' *
The plugin tries to avoid external package installation by shipping
everything it needs with the plugin, but for now, you need to work
around this, by installing the *'colorama'* package via PIP using the
OSGeo4W shell.
Regards
Andreas
Am 10.02.2026 um 17:51 schrieb Nicolas Devaux via QGIS-User:
> Hi Andrea, you will find the original error message that starts all my
> troubles. I can use internet et acces to the plugin server without any
> problem. As nothing I tried enhence my situation, I'll uninstall Qgis
> and remove all profile and regit information linked to Qgis.
> I just want to be able to re install Qgis properly to be able tu
> install any plugins, that is not the case at the moment...
> Thanks for your tips and advices if you have
> Impossible de charger l'extension 'timeseriesviewerplugin' provoque
> une erreur lors de l'appel à sa méthode classFactory()
> Traceback (most recent call last):
> File "C:\PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python\qgis\utils.py",
> line 478, in _startPlugin
> plugins[packageName] = package.classFactory(iface)
> File
> "C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\timeseriesviewerplugin\__init__.py",
> line 37, in classFactory
> from eotimeseriesviewer.eotimeseriesviewerplugin import
> EOTimeSeriesViewerPlugin
> line 1100, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\__init__.py",
> line 25, in
> from eotimeseriesviewer.qgispluginsupport.qps.pyqtgraph.pyqtgraph
> import PlotDataItem
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\__init__.py",
> line 137, in
> from .colormap import *
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\colormap.py",
> line 6, in
> from .functions import clip_array, clip_scalar, colorDistance, eq,
> mkColor
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\functions.py",
> line 19, in
> from . import Qt, debug, getConfigOption, reload
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\debug.py",
> line 28, in
> from .util import cprint
> File
> "C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin\eotimeseriesviewer\qgispluginsupport\qps\pyqtgraph\pyqtgraph\util\cprint.py",
> line 6, in
> from colorama.win32 import windll
> Version de Python :3.12.11 (main, Jun 17 2025, 13:41:12) [MSC v.1943
> 64 bit (AMD64)]
> Version de QGIS :3.40.10-Bratislava Bratislava, c98da2e682
> Chemin Python :
> * C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\eMapTools
> * C:/PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python
> * C:/Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python
> * C:/Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
> * C:/PROGRA~1/QGIS34~1.10/apps/qgis-ltr/./python/plugins
> * C:\PROGRA~1\QGIS34~1.10\apps\grass\grass84\etc\python
> * C:\Users\devaux\Documents
> * C:\Program Files\QGIS 3.40.10\bin\python312.zip
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\DLLs
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\win32
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\win32\lib
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\Pythonwin
> * C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\assets\external\xmltodict-0.13.0-py2.py3-none-any.whl
> * C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\assets\external\aenum-3.1.11-py3-none-any.whl
> * C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BioDispersal
> * C:\Users/devaux/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\BioDispersal\qgis_lib_mc
> * C:\PROGRA~1\QGIS34~1.10\apps\Python312\Lib\site-packages\setuptools\_vendor
> * C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\HCMGIS/forms
> * C:\Users\devaux\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\timeseriesviewerplugin
> Le 10/02/2026 à 17:42, Andrea Giudiceandrea via QGIS-User a écrit :
>> Hi Nicolas,
>> which QGIS version are you using exactly? On which operative system?
>> What is the URL and the status of the plugin repositories listed in
>> Plugins -> Manage and Install Plugins -> Settings? What happens if
>> you click on "Reload repository"? What happens if you browse the
>> repository URL using a web browser in the same system? Is QGIS,
>> installed in your system, able to connect to any Internet resource
>> (e.g. the OpenStreetMap XYZ Tiles server?
>> Regards.
>> Andrea
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Nicolas DEVAUX
> Laboratoire d'étude des Interactions entre Sol, Agrosystème et Hydrosystème
> UMR LISAH Montpellier SupAgro-INRA-IRD
> Bat. 24
> place Viala
> 34060 Montpellier cedex 1
> tél : +33 0(4) 99 61 25 45
> fax: +33 0(4) 67 63 26 14
> email:nicolas.devaux at supagro.fr
> http://www.supagro.fr/web/
> http://www.umr-lisah.fr/
> Je soutiens les contractuels dans leur combat pour une rémunération équitable
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/8b911269/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/8b911269/attachment.png>
More information about the QGIS-User
