[Qgis-user] Adding points as seperate layers
Andrea Giudiceandrea andreaerdna at libero.it
Wed Feb 11 07:23:49 PST 2026
Hi Mike,
looking at the provided screenshot and the issue description, the issue
is due to the fact that the first data row was used as field names when
importing the CSV.
You can clearly see it in the Identify Results panel, where the field
name are incorrectly "-79.924454","39.709589" and "M 1", instead of
"Lat","Long" and "Mile".
How did you import the CSV file exactly (which tool and which parameters
did you use)?
Regards.
Andrea
More information about the QGIS-User mailing list
