[Qgis-user] Adding points as seperate layers
ERT - Mike Breiding epicroadtrips at gmail.com
Wed Feb 11 09:46:41 PST 2026
On 2/11/2026 8:23 AM, Andrea Giudiceandrea via QGIS-User wrote:
> Hi Mike,  looking at the provided screenshot and the issue
> description, the issue is due to the fact that the first data row was
> used as field names when importing the CSV.
> You can clearly see it in the Identify Results panel, where the field
> name are incorrectly "-79.924454","39.709589" and "M 1", instead of
> "Lat","Long" and "Mile". How did you import the CSV file exactly
> (which tool and which parameters did you use)? Regards. Andrea
Hi Andrea,
I changed the import CSV settings and that solved the problem.
Please take a look and let me know if there is anything else I should
pay attention to. I was not sure what to select in the "Geometry CRS"
option.
https://photos.app.goo.gl/xQBqLq9QX3fSJ43C8
Thanks your help.
WV-Mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/5b1cc803/attachment.htm>
More information about the QGIS-User mailing list
