[Qgis-user] Adding points as seperate layers
ERT - Mike Breiding
epicroadtrips at gmail.com
Wed Feb 11 09:49:20 PST 2026
Hi Garth,
I think I got the sorted out.
See my List email to Andrea Giudiceandrea for the details.
WV-Mike
On 2/11/2026 8:39 AM, Garth Fletcher wrote:
> Select your point layer
> Click on "Open Attribute Table" tool (spreadsheet icon 3rd to right of
> "abacus icon")
> Check if your M1 is listed
> if not listed:
> it is seeing the first line as field, so that part is ok
> when loading the .CSV could you have told it to discard a header line
> this should be 0
> if listed:
> perhaps it has a third value that is neither "plain dot" nor "red dot"
> a candidate for a CASE with ELSE
> CASE
> WHEN Idx=1 THEN color_rgb(0,0,0)
> WHEN Idx=2 THEN color_rgb(255,0,0)
> ELSE color_rgb(0,255,0)
> END
> Garth Fletcher
> On 2/11/26 9:50 AM, qgis-user-request at lists.osgeo.org wrote:
>> Date: Wed, 11 Feb 2026 07:50:54 -0700
>> From: ERT - Mike Breiding<epicroadtrips at gmail.com>
>> To: David Strip<qgis-user at stripfamily.net>
>> Cc: Qgis<qgis-user at lists.osgeo.org>
>> Subject: Re: [Qgis-user] Adding points as seperate layers
>> Message-ID:<e312df5d-b106-47cb-8be5-b46335c52063 at gmail.com>
>> Content-Type: text/plain; charset="utf-8"; Format="flowed"
>> Greetings, David.
>> I followed your instructions and I am making some progress. I now have
>> two categories with individual symbologies for the Mile Marker point
>> layer.
>> However, there seems to be a problem with my CSV file or something else.
>> The layer is not displaying the first Mile Marker?point and I cannot see
>> why.
>> The first point displayed is M2, not M1.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260211/e4f2928a/attachment.htm>
More information about the QGIS-User
