[Qgis-user] Merge feature toll
Richard Greenwood
richard.greenwood at gmail.com
Fri Feb 13 08:37:34 PST 2026
The "Merge Selected Features" tool does not alter the geometries. I takes
two or more geometries and combines them into a new single "multi"
geometry. For example of you have two features in your layer that are two
separate records and you merge them you'll now have just one record for
that feature. Maybe you have a highway with two separated lanes and
you want to both lanes show as separate lines but in the data you only want
one record, then you would use the "Merge Selected Features" tool.
On Fri, Feb 13, 2026 at 8:00 AM ERT - Mike Breiding via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Greetings,
> I am trying to merge/connect two lines.
> When I select the lines, I choose the Merge tool and choose OK.
> But, the lines do not connect.
> Screenshot:
> https://photos.app.goo.gl/wh7MuSSTBvjb1eyd7
> Am I going about this the correct way?
> Thanks,
> WV-Mike
> QGIS version 3.28.4-Firenze
> WIN 11
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260213/6fda551a/attachment.htm>
More information about the QGIS-User
