[Qgis-user] Merge feature toll
ERT - Mike Breiding
epicroadtrips at gmail.com
Fri Feb 13 09:29:55 PST 2026
Thanks for this info on the use of "Merge Selected Features".
I am still looking for help on connecting two lines.
The line is a stream that is "interrupted" by a backwater.
See the screen shot:
https://photos.app.goo.gl/qr3H5HgDfWG44FP66
WV-Mike
On 2/13/2026 9:37 AM, Richard Greenwood wrote:
> The "Merge Selected Features" tool does not alter the geometries. I
> takes two or more geometries and combines them into a new single
> "multi" geometry. For example of you have two features in your layer
> that are two separate records and you merge them you'll now have just
> one record for that feature. Maybe you have a highway with two
> separated lanes and you want to both lanes show as separate lines but
> in the data you only want one record, then you would use the "Merge
> Selected Features" tool.
> On Fri, Feb 13, 2026 at 8:00 AM ERT - Mike Breiding via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
> Greetings,
> I am trying to merge/connect two lines.
> When I select the lines, I choose the Merge tool and choose OK.
> But, the lines do not connect.
> Screenshot:
> https://photos.app.goo.gl/wh7MuSSTBvjb1eyd7
> Am I going about this the correct way?
> Thanks,
> WV-Mike
> QGIS version 3.28.4-Firenze
> WIN 11
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260213/25dcbd56/attachment.htm>
More information about the QGIS-User
