[Qgis-user] Merge feature toll
Richard Greenwood
richard.greenwood at gmail.com
Fri Feb 13 09:57:08 PST 2026
I would just draw a line between the two segments. Use snap so that the new
line connects exactly to the two existing lines. And then use the "Merge
Selected Features" to merge the three features into one. But maybe you're
are looking for a way to automate this process, which is beyond my
knowledge.
Rich
On Fri, Feb 13, 2026 at 10:29 AM ERT - Mike Breiding <
epicroadtrips at gmail.com> wrote:
> Thanks for this info on the use of "Merge Selected Features".
> I am still looking for help on connecting two lines.
> The line is a stream that is "interrupted" by a backwater.
> See the screen shot:
> https://photos.app.goo.gl/qr3H5HgDfWG44FP66
> WV-Mike
> On 2/13/2026 9:37 AM, Richard Greenwood wrote:
> The "Merge Selected Features" tool does not alter the geometries. I takes
> two or more geometries and combines them into a new single "multi"
> geometry. For example of you have two features in your layer that are two
> separate records and you merge them you'll now have just one record for
> that feature. Maybe you have a highway with two separated lanes and
> you want to both lanes show as separate lines but in the data you only want
> one record, then you would use the "Merge Selected Features" tool.
> On Fri, Feb 13, 2026 at 8:00 AM ERT - Mike Breiding via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Greetings,
>> I am trying to merge/connect two lines.
>> When I select the lines, I choose the Merge tool and choose OK.
>> But, the lines do not connect.
>> Screenshot:
>> https://photos.app.goo.gl/wh7MuSSTBvjb1eyd7
>> Am I going about this the correct way?
>> Thanks,
>> WV-Mike
>> QGIS version 3.28.4-Firenze
>> WIN 11
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Richard W. Greenwood
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260213/4ebf9a40/attachment.htm>
More information about the QGIS-User
