[Qgis-user] aggregate polygon overlay
Simon Dietmann
dietmann at pgnu.de
Tue Feb 17 06:00:35 PST 2026
Dear list,
I am trying to solve the following problem:
I have one polygon layer with many polygons that are in many cases overlapping and with different attribute valus, e.g. a, b, c:
[cid:image001.png at 01DCA01D.DFC66850]
My goal is to generate a polygon layer with polygons for every overlap constellation containing a concat string of those attributes, in this example seven polygons with the attributes a, b, c, ab, bc, ac, abc.
I started with a union of my original layer, the result is a layer with 12 polygons where overlapping areas of the original polygons result in overlapping intersections containing one of the original attributes each, for example in the middle, there are 3 polygons, one with a, one with b and one with c.
How is it possible to summarize those overlapping polygons into one polygon each with all the attributes, given that there is a large number of polygons and different attributes?
Thank you for any hints,
regards
Simon
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260217/90de7c8b/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260217/90de7c8b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260217/90de7c8b/attachment-0003.png>
More information about the QGIS-User
