[Qgis-user] Convert geocentric x, y, z to projected coordinates
Kirk Schmidt
kirk at nortekresources.com
Fri Feb 27 07:14:27 PST 2026
Hi Roland:
Something seems wrong with your data. The z elevation is 4736 km which
is a bit high for terrestrial mapping applications.
Kirk Schmidt
On 2/27/2026 8:33 AM, Roland Spielhofer via QGIS-User wrote:
> Hi,
> I have a set of coordinates as geocentric x, y, z 3D-coordinates in
> ETRF89 (located in Austria), which should be, if I am not wrong,
> EPSG:7194.
> It is a CSV file.
> As an example:
> x y z
> 4080019.8005 1202964.0971 4736921.5758
> When I import it via "Data source manager/delimited text", I select
> EPGS:7194 as CRS and assign the x to "X-field", y to the "Y-Field" and
> z to the "Z-Field".
> The QGIS project itself is in ETRS89/UTM33 - and this is the target
> system I eventually want my points in.
> When I add a basemap and compare the points created, they all lie
> around the equator.
> I also tried different EPSG during import, e.g. EPSG:4346, but the
> points created stay at the same [wrong] location.
> How do I do the import to end up having points at the right locations?
> Thanks in advance!
> Roland
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Kirk Schmidt, MScF, BScF, RPF
General Manager
Nortek Resource Solutions Inc.
26 Church Road
Sutherlands River, NS
B0K 1W0
Tel (902) 922.3607
Email:kirk at nortekresources.com
Web:www.nortekresources.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260227/ad81c9ec/attachment.htm>
More information about the QGIS-User
