[Qgis-user] Convert geocentric x, y, z to projected coordinates
Greg Troxel gdt at lexort.com
Fri Feb 27 07:45:42 PST 2026
Roland Spielhofer via QGIS-User <qgis-user at lists.osgeo.org> writes:
> I have a set of coordinates as geocentric x, y, z 3D-coordinates in ETRF89 (located in Austria), which should be, if I am
> not wrong, EPSG:7194.
I do not find EPSG:7194 in proj as a CRS.   It seems to be an operation
code for a US state plane system in ftUS.  Surely not in use in Austria!
Perhaps you mean EPSG:7914?
I would use cs2cs on the command line and get things straightened out
there, and then check in qgis.
More information about the QGIS-User mailing list
