[Qgis-user] DEM to contours
Karlo no Dabas maajas
karlo at latnet.lv
Thu Jan 15 07:44:43 PST 2026
Hi!
I have used “gdal_contour” for deriving contours.
https://gdal.org/en/stable/programs/gdal_contour.html
The QGIS interface for this tool is quite incomplete. If you are afraid
of terminal window, then the “Additional command line parameters” should
be specified.
Best regards,
Kārlis
.P.S. Sooner or later You should learn to use scripts as QGIS is not
designed for raster analises :)
15.01.26 15:59, Riaan Botes via QGIS-User rakstīja:
> QGIS Desktop 3.44.4 (Qt6)
> I am trying to get a contour(s) line(s) derived from a DEM. I am using
> the Raster Extractor (from Raster Processing Tool).
> The problem with this tool is that it does not appear to have a MIN/MAX
> function. So it get over 1.5 million line segments.
> Is there a way to define the contour OR is there another tool I can use?
> Riaan
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User
