[Qgis-user] DEM to contours
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Jan 15 08:07:44 PST 2026
Hi Riaan,
if you want to create contour lines only between a minimum and maximum
elevation from a DEM raster layer, then you could use the GRASS
"r.contour" processing algorithm in QGIS.
Using such processing algorithm you can specify the "Minimum contour
level" and the "Maximum contour level" parameters.
Regards.
Andrea
> riaanb at iafrica.com riaanb at iafrica.com
> Thu Jan 15 05:59:10 PST 2026
> I am trying to get a contour(s) line(s) derived from a DEM.
> The problem with this tool is that it does not appear to have a MIN/MAX
> function.
More information about the QGIS-User
