[Qgis-user] Hardware Recommendations for a High-End PC for QGIS 3.40.14 “Bratislava”
Zoltan Szecsei
zoltans at geograph.co.za
Wed Jan 21 06:38:38 PST 2026
How long is a piece of string?
You might get a more accurate answer to that question 🙂
So, to try to be more useful to you:
* If Intel, at least i9 "top-end". Look at the number of CPU/threads
but almost more importantly look at the CPU clock speed as the
higher CPU counts can lead to slower clock speed. You can play
around with CPU comparisons on a number of websites. (currently I
would tend towards AMD, though)
* Minimum 32GB, preferably 64GB or even 128GB if budget allows.
Perhaps avoid ECC as it does run (noticeably???) slower.
* In terms of motherboard design, take 'notice' of the number of PCIe
lanes available and how fast/what Gen they are.
* Only use NVMe 'drives', not SATA SSD or 'normal' HDs
* Graphics cards? I am not sure where the price-break between gaming
and 'professional' cards is - *maybe someone else on this list can
help here*.
* Don't forget to have a "few" decent USB ports - at least 3.2 Gen2 x
2 (20Gbps) or USB 4 (40Gbps, even 80Gbps) - But remember that if you
are transferring hundreds of small files (as in multiple File-GDBs)
the file-system as formatted on the USB will have a major impact
(downwards) on your transfer speeds.
* Try to have at least 2.5Gbps network, if 10Gbps not affordable - but
then to benefit from this you will need to connect to an appropriate
network.
I run a 2023 Dell Mobile Precision Workstation 7780 with i9-1390HX,
128GB CAMM non-ECC, RTX-A5000 Ada and a 1TB NVMe for system, plus
another 3 * 8TB Sabrent PCIe 4 NVMe SSDs.
Overkill perhaps, but one gets used to this too quickly and still
complains about "this slow piece of rubbish!!!" 😂😂
Not sure if you mean _/stereo/_ 3D visualisation - if yes, you could end
up spending more on the (Pluraview?) 3D monitor.....
Hope I've helped a bit, at least.
Regards and have fun,
Zoltan
On 2026/01/21 15:50, Bjørn Magne Stock via QGIS-User wrote:
> Hi
> I hope you are doing well. I am contacting you to request guidance on
> recommended hardware specifications for a new workstation that will be
> used primarily for QGIS.
> *What we are expecting to get:*
> We want to purchase a new PC that is *in the top performance range*,
> optimized for professional use in QGIS.
> Could you please advise on the recommended *hardware requirements*
> (CPU, GPU, RAM, storage, etc.) for best performance with QGIS 3.40.14,
> including demanding GIS workflows such as:
> * Large raster datasets
> * Complex vector layers and geoprocessing
> * 3D visualization (if relevant)
> * Rendering and analysis of large projects
> Best regards
> *Bjørn Magne Stock*
> Fagleder – Plattform | *www.ffk.no* <https://www.ffk.no/>
> *T: *+4778963128
> *M: *+4795992275
> bjorn.magne.stock at ffk.no <mailto:bjorn.magne.stock at ffk.no>
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Zoltan Szecsei GPrGISc 0031
Director, Geograph (Pty) Ltd.
GIS and Photogrammetric Services
Cape Town, South Africa.
Mobile: +27-83-6004028 (Signal, not WhatsApp)
+36-20-3594428
www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260121/7f3ea332/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260121/7f3ea332/attachment-0001.png>
More information about the QGIS-User
