[Qgis-user] Fwd: QGIS 3.44.11 query
chris hermansen
clhermansen at gmail.com
Wed Jun 3 12:36:17 PDT 2026
Simon and list,
On Wed, Jun 3, 2026, 12:22 Simon Prentice via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello QGIS
> I've been trying to use QGIS 3.44.11 ( QGIS-OSGeo4W-3.44.11-1 ) on my
> Windows laptop to overlay the attached files as recommended by an AI tool
> which suggested I do the following:
> '*The GIS Route (Recommended for large lists):* Import your Pacifecon CSV
> file and the downloaded Auckland Council SMAF shapefile into *QGIS*.
> Geocode your project addresses into points, and run a *Spatial Join*
> (Point-in-Polygon query) to instantly tag which projects fall inside a SMAF
> 1 or SMAF 2 polygon.'
> [image: image.png]
> Can you direct me as to how I use this platform to overlay the attached
> files to target new building projects that are within the
> 'Stormwater-management-area-control' zones please.
> Thank you
There is considerable and good documentation on topics such as spatial
overlay in QGIS, for example:
https://docs.qgis.org/3.44/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html
It could be wise to review some of that, which will likely help you find a
solution.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260603/4b430446/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260603/4b430446/attachment.png>
More information about the QGIS-User
