[Qgis-user] Issue with installing SAGA plugin in QGIS 3.44 version software
Nagachaitra N
nagachaitra at pemsconsultants.com
Fri Jun 5 01:09:54 PDT 2026
Hi Andrea,
I am tried downloading the SAGA from the above link, But when I input DEM
File into QGIS, I am getting the negative value of elevation, also even after filling the sinks and also in the Strahler order
As the minimum value is to be 1, but I am getting the negative values. Not able to understand why I am I getting the negative values
And what is the solution for the same.
It would be helpful for me with any proper solution for this issue.
[cid:33c54be5-bf06-4c77-98a6-0d81ec712e02]
Thanks and Regards
Nagachaitra N
PEMS Engineering Consultants Pvt. Ltd.
Bengaluru, Karnataka - 560043
From: Andrea Giudiceandrea <andreaerdna at libero.it>
Sent: Wednesday, June 3, 2026 6:09 PM
To: qgis-user at lists.osgeo.org <qgis-user at lists.osgeo.org>
Cc: Nagachaitra N <nagachaitra at pemsconsultants.com>
Subject: Re: [Qgis-user] Issue with installing SAGA plugin in QGIS 3.44 version software
Il 03/06/2026 10:08, Nagachaitra N ha scritto:
> I got the file from this website
> https://sourceforge.net/projects/saga-gis/files/
AFAIK, the zip file of the "Processing Saga NextGen Provider" QGIS
plugin is not available at https://sourceforge.net/projects/saga-gis/files/
That page provides the SAGA-GIS source code and executable files, not
the "Processing Saga NextGen Provider" QGIS plugin.
You can find the zip file of the "Processing Saga NextGen Provider"
plugin version 1.1.0 at
https://github.com/agiudiceandrea/qgis-processing-saga-nextgen/releases/download/1.1.0/processing_saga_nextgen-1.1.0.zip
Regards.
Andrea
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260605/0c707379/attachment-0001.htm>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260605/0c707379/attachment-0001.png>
More information about the QGIS-User
