[Qgis-user] Issue with installing SAGA plugin in QGIS 3.44 version software
Andrea Giudiceandrea
andreaerdna at libero.it
Fri Jun 5 01:49:16 PDT 2026
> Nagachaitra N nagachaitra at pemsconsultants.com
> Fri Jun 5 01:09:54 PDT 2026
> I am tried downloading the SAGA from the above link, But when I input DEM
> File into QGIS,
Hi Nagachaitra N,
I guess it means you have managed to install the "Processing Saga
NextGen Provider" plugin from
https://github.com/agiudiceandrea/qgis-processing-saga-nextgen/releases/download/1.1.0/processing_saga_nextgen-1.1.0.zip
Is it right?
If so, please firstly confirm that you have actually fixed the "issue
with installing SAGA plugin in QGIS 3.44 version software".
If you have now an issues using a SAGA-GIS processing tool, I suggest
you to try if the issue occurs also directly using the SAGA-GIS
application and tools, instead of the corresponding SAGA-GIS processing
algorithm in QGIS.
If it does, then you need to correctly understand if the workflow, the
parameters and the input file are correctly chosen and if your expected
results are correctly expected, also reading the SAGA-GIS tool manual.
Having ascertained this, then the issue may be due to a bug in the
SAGA-GIS tool itself and should be reported to the SAGA-GIS developers.
If the issue doesn't occur directly using SAGA-GIS, but only using the
corresponding SAGA-GIS processing algorithm in QGIS, or if you are not
able to directly using SAGA-GIS, then I suggest you to send a new
message with a proper subject to the mailing list, providing all the
details needed to correctly understand the issue, like the details about
the layers involved, the processing algorithm and the parameters used.
Providing a link to download the input layer file, if possible, would be
also useful.
Regards.
Andrea
More information about the QGIS-User
