[Qgis-user] Fw: QGIS in Conda env
Rafael Abrantes Machado rafael.a.machado at gmail.com
Sun Jun 21 06:46:20 PDT 2026
Hello
Just to make sure, did you activate the conda env where qgis was installed
before running qgis?
Regards
Em sáb., 20 de jun. de 2026 às 15:42, Micha Silver via QGIS-User <
qgis-user at lists.osgeo.org> escreveu:
> Sorry for the double posting. :-(
> My registration on the list didn't go thru at first, so I re-registered
> and posted again. I guess the earlier posts eventually got thru after the
> first registration was confirmed.
> *Micha Silver*
> *tel: +972-523665918*
> On Friday, June 19th, 2026 at 4:20 PM, Micha Silver via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
> I'm stuck trying to get QGIS working in a conda environment. My system is
> Debian 13. I setup environments with python 3.11, 3.12 and 3.13. I then
> installed QGIS 3.40, 3.44.7 and 3.44.9 in those environments. The
> installation goes OK, but in all cases, starting QGIS ends in a crash with:
> QGIS died on signal 11[New LWP 17048]
> ...many lines of debug info...
> Aborted (core dumped)
> I try to run QGIS with:
> qgis -n -P --profile new
> I should add that the native QGIS.org *.deb installed on this computer
> works fine (outside of conda).
> And furthermore, in a separate Debian 12 laptop, the conda installed QGIS
> 3.44.7 works OK.
> I'd like to have the conda installation working since the EnMAPbox plugin
> requires certain python packages that are not available in Debian. So the
> EnMAPbox devs recommend to setup the conda environment.
> Any suggestions are welcome.
> Thanks, and kind regards,
> Micha
> *Micha Silver*
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260621/bd19969d/attachment.htm>
More information about the QGIS-User mailing list
