[Qgis-user] Fw: QGIS in Conda env
Micha Silver
micha_silver+GIS at proton.me
Sun Jun 21 09:14:46 PDT 2026
Micha Silvercell: +972-523-665918
On Sunday, June 21st, 2026 at 4:46 PM, Rafael Abrantes Machado via QGIS-User <qgis-user at lists.osgeo.org> wrote:
> Hello
> Just to make sure, did you activate the conda env where qgis was installed before running qgis?
> Yes, of course :-)
> Regards
> Em sáb., 20 de jun. de 2026 às 15:42, Micha Silver via QGIS-User <qgis-user at lists.osgeo.org> escreveu:
>> Sorry for the double posting. :-(
>> My registration on the list didn't go thru at first, so I re-registered and posted again. I guess the earlier posts eventually got thru after the first registration was confirmed.
>> Micha Silver
>> tel: +972-523665918
>> On Friday, June 19th, 2026 at 4:20 PM, Micha Silver via QGIS-User <qgis-user at lists.osgeo.org> wrote:
>>>> I'm stuck trying to get QGIS working in a conda environment. My system is Debian 13. I setup environments with python 3.11, 3.12 and 3.13. I then installed QGIS 3.40, 3.44.7 and 3.44.9 in those environments. The installation goes OK, but in all cases, starting QGIS ends in a crash with:
>>>> QGIS died on signal 11[New LWP 17048]
>>>> ...many lines of debug info...
>>>> Aborted (core dumped)
>>>> I try to run QGIS with:
>>>> qgis -n -P --profile new
>>>> I should add that the native QGIS.org *.deb installed on this computer works fine (outside of conda).
>>>> And furthermore, in a separate Debian 12 laptop, the conda installed QGIS 3.44.7 works OK.
>>>> I'd like to have the conda installation working since the EnMAPbox plugin requires certain python packages that are not available in Debian. So the EnMAPbox devs recommend to setup the conda environment.
>>>> Any suggestions are welcome.
>>>> Thanks, and kind regards,
>>>> Micha
>>>> Micha Silver
>>>> tel: +972-523665918
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260621/e24554cb/attachment.htm>
More information about the QGIS-User
