[Qgis-user] Fw: QGIS in Conda env
Roland Berger
roland.berger at steinerpartner.com
Sun Jun 21 09:15:43 PDT 2026
Hi
I just installed similar on linux mint. The default qca dependency is
wired to QT6. But QGIS 3.4 is still on QT5. So you need a specific
version of qca which has dependencies to QT5. Well, that is what claude
told me. For me the following works:
1. conda create -n qgis-344_py313 -c conda-forge qgis=3.44.9
python=3.13.14 "qca=2.3.10=h71e8f01_0" -y
2. conda activate qgis-344_py313
3. conda run qgis
Hope this helps
Roland
On 6/20/26 20:40, Micha Silver via QGIS-User wrote:
> Sorry for the double posting. :-(
> My registration on the list didn't go thru at first, so I
> re-registered and posted again. I guess the earlier posts eventually
> got thru after the first registration was confirmed.
> /Micha Silver/
> /tel: +972-523665918/
> On Friday, June 19th, 2026 at 4:20 PM, Micha Silver via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>>> I'm stuck trying to get QGIS working in a conda environment. My
>>> system is Debian 13. I setup environments with python 3.11, 3.12 and
>>> 3.13. I then installed QGIS 3.40, 3.44.7 and 3.44.9 in those
>>> environments. The installation goes OK, but in all cases, starting
>>> QGIS ends in a crash with:
>>> QGIS died on signal 11[New LWP 17048]
>>> ...many lines of debug info...
>>> Aborted (core dumped)
>>> I try to run QGIS with:
>>> qgis -n -P --profile new
>>> I should add that the native QGIS.org *.deb installed on this
>>> computer works fine (outside of conda).
>>> And furthermore, in a separate Debian 12 laptop, the conda installed
>>> QGIS 3.44.7 works OK.
>>> I'd like to have the conda installation working since the EnMAPbox
>>> plugin requires certain python packages that are not available in
>>> Debian. So the EnMAPbox devs recommend to setup the conda environment.
>>> Any suggestions are welcome.
>>> Thanks, and kind regards,
>>> Micha
>>> /Micha Silver/
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260621/d394c3c2/attachment-0001.htm>
More information about the QGIS-User
