[Qgis-user] QGIS problem
Юліана
yulianasabat0 at gmail.com
Thu Jun 25 02:17:52 PDT 2026
Thank you, but I know my way around raster files. The problem is that the
file I need opens on another laptop but not on mine, so I'd appreciate some
help with this
чт, 25 черв. 2026 р., 3:44 AM користувач Mike Bundock <mike at augview.net>
пише:
> Hi
> i really strongly recommend you read the documentation and have a basic
> understanding of raster data file types. xml files are text files.
> - See https://en.wikipedia.org/wiki/GIS_file_format#Raster_formats
> - the QGIS user documentation on adding layers
> - or in chrome use the AI response to 'qgis add raster layer'
> - or qgis supported raster layer formats
> - there are many qgis youtube tutorials of varying quality but try
> https://www.youtube.com/watch?v=Qz54AE_Tc9I
> I suspect the most often used raster file types used will be geotiff
> (*.tif or *.tiff) but as you can see from the documentation there are 140
> supported formats.
> regards
> regards
> *Mike Bundock* | CEO
> Augview | P O Box 125046, St Heliers, Auckland 1740, New Zealand
> p: +64 9 575 5298 | m: +64 27 575 5298 | e:
> mailto:mike.bundock at augview.net <mike.bundock at augview.net>| w:
> www.augview.net
> Winner of Innovation & Commercialisation and Supreme Awards at 2014 NZ
> Spatial Excellence Awards
> Winner of Innovation & Commercialisation Award at 2014 Asia Pacific
> On Thu, 25 Jun 2026 at 05:43, Юліана via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> Hello!
>> I'm using QGIS version 3.44.11.
>> Here are the details of the problem: I was working on a task in this
>> program when it suddenly crashed. The files I'm using are stored on my hard
>> drive. So, I opened the file I needed on another device to check it, and
>> everything works perfectly there—it opens and can be dragged just as it
>> should. The other device has the same version of the program (3.44.11). But
>> on my device, I get an error (see the screenshot below). I’m sure the
>> problem is with the program itself, since this happened after everything
>> else stopped working: at one point, I lost the ability to open polygons,
>> which took me some time to figure out. Later, I was able to do that, but
>> the files still wouldn’t drag and drop. I also know it’s not a disk issue,
>> because I can drag and drop other files from it, but the specific one I
>> need won’t work. The files are fine—it’s just the situation I described—and
>> everything works perfectly on another device. I’d appreciate some help with
>> this issue. Thanks in advance.
>> The operating system I’m using is Windows.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260625/73cedf56/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260625/73cedf56/attachment-0001.jpg>
More information about the QGIS-User
