[Qgis-user] QGIS problem
Mike Bundock
mike at augview.net
Wed Jun 24 17:44:27 PDT 2026
Hi
i really strongly recommend you read the documentation and have a basic
understanding of raster data file types. xml files are text files.
- See https://en.wikipedia.org/wiki/GIS_file_format#Raster_formats
- the QGIS user documentation on adding layers
- or in chrome use the AI response to 'qgis add raster layer'
- or qgis supported raster layer formats
- there are many qgis youtube tutorials of varying quality but try
https://www.youtube.com/watch?v=Qz54AE_Tc9I
I suspect the most often used raster file types used will be geotiff (*.tif
or *.tiff) but as you can see from the documentation there are 140
supported formats.
regards
regards
*Mike Bundock* | CEO
Augview | P O Box 125046, St Heliers, Auckland 1740, New Zealand
p: +64 9 575 5298 | m: +64 27 575 5298 | e: mailto:mike.bundock at augview.net
<mike.bundock at augview.net>| w: www.augview.net
Winner of Innovation & Commercialisation and Supreme Awards at 2014 NZ
Spatial Excellence Awards
Winner of Innovation & Commercialisation Award at 2014 Asia Pacific Spatial
Excellence Awards
On Thu, 25 Jun 2026 at 05:43, Юліана via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> Hello!
> I'm using QGIS version 3.44.11.
> Here are the details of the problem: I was working on a task in this
> program when it suddenly crashed. The files I'm using are stored on my hard
> drive. So, I opened the file I needed on another device to check it, and
> everything works perfectly there—it opens and can be dragged just as it
> should. The other device has the same version of the program (3.44.11). But
> on my device, I get an error (see the screenshot below). I’m sure the
> problem is with the program itself, since this happened after everything
> else stopped working: at one point, I lost the ability to open polygons,
> which took me some time to figure out. Later, I was able to do that, but
> the files still wouldn’t drag and drop. I also know it’s not a disk issue,
> because I can drag and drop other files from it, but the specific one I
> need won’t work. The files are fine—it’s just the situation I described—and
> everything works perfectly on another device. I’d appreciate some help with
> this issue. Thanks in advance.
> The operating system I’m using is Windows.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260625/7d59bb2b/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260625/7d59bb2b/attachment-0001.jpg>
More information about the QGIS-User
