[Qgis-user] QGIS problem
Юліана
yulianasabat0 at gmail.com
Wed Jun 24 12:48:48 PDT 2026
Yes, there are 5 files shown in the photo because I closed some of them;
generally, not all the files in the photo are loaded.
That's right—dragging files isn't done through the windows, but via "Layer"
> "Add Layer" > "Add Raster Layer," and that doesn't work either.
ср, 24 черв. 2026 р., 10:38 PM користувач David Koster <david.lade at gmx.de>
пише:
> You mention five files, but the screenshot shows eight.
> As far as I know, the .aux.xml and .hdr files only contain metadata, and
> the .xml files are vector data. Unfortunately, I don't see any actual
> raster data there. Sorry!
> Am 24.06.2026 um 21:12 schrieb Юліана via QGIS-User:
> There are 5 issues—these are the 5 files I’m dragging. I’m having a
> problem with each one (the files won’t drag individually, but I can’t do it
> this way either because I need all of them)
> (I’ve hidden the file names, but here are the file types I’m dragging);
> everything used to work fine, and they open perfectly on another device
> I’m dragging files from a window on my computer. I select the files and
> drag them from the window into an open QGIS window. I also tried adding
> them individually via Raster, but it still doesn’t work.
> Yes, the problem occurs in a new project, and I’ve also reinstalled the
> program, but that didn’t help.
> ср, 24 черв. 2026 р., 10:04 PM користувач Ludwig Kniprath <
> ludwig at kni-online.de> пише:
>> Hi,
>> "Invalid Data Source" normally means, that you dragged an unsupported
>> file-type. However, your message is missing some important details, so
>> it's difficult to offer further advice:
>> Are you dragging files from filesystem (Windows-Explorer) to the
>> QGis-Window?
>> What kind of file are you dragging onto the QGis-Window? (Unfortunately,
>> this interesting part was obfuscated in your screenshot...)
>> Does the problem occur in a blank new project?
>> What are the "5 more" problems reported in your screenshot? (Note: You
>> can see a list of all messages in the "Log Messages Panel")
>> Regards
>> Ludwig
>> Am 24.06.26 um 19:43 schrieb Юліана via QGIS-User:
>> Hello!
>> I'm using QGIS version 3.44.11.
>> Here are the details of the problem: I was working on a task in this
>> program when it suddenly crashed. The files I'm using are stored on my hard
>> drive. So, I opened the file I needed on another device to check it, and
>> everything works perfectly there—it opens and can be dragged just as it
>> should. The other device has the same version of the program (3.44.11). But
>> on my device, I get an error (see the screenshot below). I’m sure the
>> problem is with the program itself, since this happened after everything
>> else stopped working: at one point, I lost the ability to open polygons,
>> which took me some time to figure out. Later, I was able to do that, but
>> the files still wouldn’t drag and drop. I also know it’s not a disk issue,
>> because I can drag and drop other files from it, but the specific one I
>> need won’t work. The files are fine—it’s just the situation I described—and
>> everything works perfectly on another device. I’d appreciate some help with
>> this issue. Thanks in advance.
>> The operating system I’m using is Windows.
>> QGIS-User mailing listQGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/80b93898/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/80b93898/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/80b93898/attachment-0003.jpg>
More information about the QGIS-User
