[Qgis-user] QGIS problem
David Koster
david.lade at gmx.de
Wed Jun 24 12:38:34 PDT 2026
You mention five files, but the screenshot shows eight.
As far as I know, the |.aux.xml| and |.hdr| files only contain metadata,
and the |.xml| files are vector data. Unfortunately, I don't see any
actual raster data there. Sorry!
Am 24.06.2026 um 21:12 schrieb Юліана via QGIS-User:
> There are 5 issues—these are the 5 files I’m dragging. I’m having a
> problem with each one (the files won’t drag individually, but I can’t
> do it this way either because I need all of them)
> (I’ve hidden the file names, but here are the file types I’m
> dragging); everything used to work fine, and they open perfectly on
> another device
> I’m dragging files from a window on my computer. I select the files
> and drag them from the window into an open QGIS window. I also tried
> adding them individually via Raster, but it still doesn’t work.
> Yes, the problem occurs in a new project, and I’ve also reinstalled
> the program, but that didn’t help.
> ср, 24 черв. 2026 р., 10:04 PM користувач Ludwig Kniprath
> <ludwig at kni-online.de> пише:
> Hi,
> "Invalid Data Source" normally means, that you dragged an
> unsupported file-type. However, your message is missing some
> important details, so it's difficult to offer further advice:
> Are you dragging files from filesystem (Windows-Explorer) to the
> QGis-Window?
> What kind of file are you dragging onto the QGis-Window?
> (Unfortunately, this interesting part was obfuscated in your
> screenshot...)
> Does the problem occur in a blank new project?
> What are the "5 more" problems reported in your screenshot? (Note:
> You can see a list of all messages in the "Log Messages Panel")
> Regards
> Ludwig
> Am 24.06.26 um 19:43 schrieb Юліана via QGIS-User:
>> Hello!
>> I'm using QGIS version 3.44.11.
>> Here are the details of the problem: I was working on a task in
>> this program when it suddenly crashed. The files I'm using are
>> stored on my hard drive. So, I opened the file I needed on
>> another device to check it, and everything works perfectly
>> there—it opens and can be dragged just as it should. The other
>> device has the same version of the program (3.44.11). But on my
>> device, I get an error (see the screenshot below). I’m sure the
>> problem is with the program itself, since this happened after
>> everything else stopped working: at one point, I lost the ability
>> to open polygons, which took me some time to figure out. Later, I
>> was able to do that, but the files still wouldn’t drag and drop.
>> I also know it’s not a disk issue, because I can drag and drop
>> other files from it, but the specific one I need won’t work. The
>> files are fine—it’s just the situation I described—and everything
>> works perfectly on another device. I’d appreciate some help with
>> this issue. Thanks in advance.
>> The operating system I’m using is Windows.
>> QGIS-User mailing list
>> QGIS-User at lists.osgeo.org
>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/3d688183/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/3d688183/attachment-0001.jpg>
More information about the QGIS-User
