[Qgis-user] QGIS problem
Юліана yulianasabat0 at gmail.com
Wed Jun 24 12:12:23 PDT 2026
There are 5 issues—these are the 5 files I’m dragging. I’m having a problem
with each one (the files won’t drag individually, but I can’t do it this
way either because I need all of them)
(I’ve hidden the file names, but here are the file types I’m dragging);
everything used to work fine, and they open perfectly on another device
I’m dragging files from a window on my computer. I select the files and
drag them from the window into an open QGIS window. I also tried adding
them individually via Raster, but it still doesn’t work.
Yes, the problem occurs in a new project, and I’ve also reinstalled the
program, but that didn’t help.
ср, 24 черв. 2026 р., 10:04 PM користувач Ludwig Kniprath <
ludwig at kni-online.de> пише:
> Hi,
> "Invalid Data Source" normally means, that you dragged an unsupported
> file-type. However, your message is missing some important details, so
> it's difficult to offer further advice:
> Are you dragging files from filesystem (Windows-Explorer) to the
> QGis-Window?
> What kind of file are you dragging onto the QGis-Window? (Unfortunately,
> this interesting part was obfuscated in your screenshot...)
> Does the problem occur in a blank new project?
> What are the "5 more" problems reported in your screenshot? (Note: You can
> see a list of all messages in the "Log Messages Panel")
> Regards
> Ludwig
> Am 24.06.26 um 19:43 schrieb Юліана via QGIS-User:
> Hello!
> I'm using QGIS version 3.44.11.
> Here are the details of the problem: I was working on a task in this
> program when it suddenly crashed. The files I'm using are stored on my hard
> drive. So, I opened the file I needed on another device to check it, and
> everything works perfectly there—it opens and can be dragged just as it
> should. The other device has the same version of the program (3.44.11). But
> on my device, I get an error (see the screenshot below). I’m sure the
> problem is with the program itself, since this happened after everything
> else stopped working: at one point, I lost the ability to open polygons,
> which took me some time to figure out. Later, I was able to do that, but
> the files still wouldn’t drag and drop. I also know it’s not a disk issue,
> because I can drag and drop other files from it, but the specific one I
> need won’t work. The files are fine—it’s just the situation I described—and
> everything works perfectly on another device. I’d appreciate some help with
> this issue. Thanks in advance.
> The operating system I’m using is Windows.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/2f0ce101/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/2f0ce101/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/2f0ce101/attachment-0004.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/2f0ce101/attachment-0005.jpg>
More information about the QGIS-User mailing list
