[Qgis-user] QGIS problem
Ludwig Kniprath
ludwig at kni-online.de
Wed Jun 24 12:04:42 PDT 2026
"Invalid Data Source" normally means, that you dragged an unsupported
file-type. However, your message is missing some important details, so
it's difficult to offer further advice:
Are you dragging files from filesystem (Windows-Explorer) to the
QGis-Window?
What kind of file are you dragging onto the QGis-Window? (Unfortunately,
this interesting part was obfuscated in your screenshot...)
Does the problem occur in a blank new project?
What are the "5 more" problems reported in your screenshot? (Note: You
can see a list of all messages in the "Log Messages Panel")
Regards
Ludwig
Am 24.06.26 um 19:43 schrieb Юліана via QGIS-User:
> Hello!
> I'm using QGIS version 3.44.11.
> Here are the details of the problem: I was working on a task in this
> program when it suddenly crashed. The files I'm using are stored on my
> hard drive. So, I opened the file I needed on another device to check
> it, and everything works perfectly there—it opens and can be dragged
> just as it should. The other device has the same version of the
> program (3.44.11). But on my device, I get an error (see the
> screenshot below). I’m sure the problem is with the program itself,
> since this happened after everything else stopped working: at one
> point, I lost the ability to open polygons, which took me some time to
> figure out. Later, I was able to do that, but the files still wouldn’t
> drag and drop. I also know it’s not a disk issue, because I can drag
> and drop other files from it, but the specific one I need won’t work.
> The files are fine—it’s just the situation I described—and everything
> works perfectly on another device. I’d appreciate some help with this
> issue. Thanks in advance.
> The operating system I’m using is Windows.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/36a09141/attachment-0001.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260624/36a09141/attachment-0001.jpg>
More information about the QGIS-User
