[Qgis-user] Data (shape files, gpka) transfer from QFIELD back to original project
Greg Troxel gdt at lexort.com
Mon May 11 10:46:06 PDT 2026
Michael Lutze via QGIS-User <qgis-user at lists.osgeo.org> writes:
> Dear QGIS Community,
> I am a beginner in QGIS and QField (Version 3.44 in QGIS).
> I have a problem exporting shapefiles or GeoPackages from QField back into
> my QGIS project. I am using a cable connection for the transfer.
> I was able to transfer the project from my PC to my tablet and carry out
> fieldwork. I can see the results on the map in QField.
You said "transfer".  You didn't say "package for cable" in qgis using
the qfield plugin, transfer that directory toa directory on which kind
of device and then importing that into qfield, capturing in qfield, and
then exporting to a directory and copying that directory back to the
qgis machine.
Maybe that's not what you did.  But your question is woefully vague.
Did you just transfer a data file, and not a project?
> I follow the instructions I found and export the entire folder from my
> tablet back to my PC. I then import (drag and drop) the GPKG into the
> original project. The symbology, etc. is transferred, but none of the
> results of my fieldwork appear—meaning the objects digitized in the field
> are missing.
Where did you read in the documentation that this was a reasonable thing
to do?
What happened when you inspected the gpkg file with ogrinfo?
> Then I used the following method:
> *Using QFieldSync *
I don't use that, so with any luck someone else will help.
> [image: image.png]
That's hard to see in plain text :-)
More information about the QGIS-User mailing list
