[Qgis-user] Fwd: Data (shape files, gpka) transfer from QFIELD back to original project
Michael Lutze
dr.michael.lutze at googlemail.com
Sun May 17 02:14:04 PDT 2026
Dear Greg, dear qgis community,
thanks for your reply.
Well I did everything right to tranfer the project to qfield.
But the transfer back was not clear for me and I made obviousley a mistake,
maybe I did not understand well the workflow (following a video/
instructions).
With my second project it workes well! The first is "going by the wind...".
Cheers
Michael
Am Mo., 11. Mai 2026 um 19:46 Uhr schrieb Greg Troxel via QGIS-User <
qgis-user at lists.osgeo.org>:
> Michael Lutze via QGIS-User <qgis-user at lists.osgeo.org> writes:
> > Dear QGIS Community,
> > I am a beginner in QGIS and QField (Version 3.44 in QGIS).
> > I have a problem exporting shapefiles or GeoPackages from QField back
> into
> > my QGIS project. I am using a cable connection for the transfer.
> > I was able to transfer the project from my PC to my tablet and carry out
> > fieldwork. I can see the results on the map in QField.
> You said "transfer". You didn't say "package for cable" in qgis using
> the qfield plugin, transfer that directory toa directory on which kind
> of device and then importing that into qfield, capturing in qfield, and
> then exporting to a directory and copying that directory back to the
> qgis machine.
> Maybe that's not what you did. But your question is woefully vague.
> Did you just transfer a data file, and not a project?
> > I follow the instructions I found and export the entire folder from my
> > tablet back to my PC. I then import (drag and drop) the GPKG into the
> > original project. The symbology, etc. is transferred, but none of the
> > results of my fieldwork appear—meaning the objects digitized in the field
> > are missing.
> Where did you read in the documentation that this was a reasonable thing
> to do?
> What happened when you inspected the gpkg file with ogrinfo?
> > Then I used the following method:
> > *Using QFieldSync *
> I don't use that, so with any luck someone else will help.
> > [image: image.png]
> That's hard to see in plain text :-)
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260517/e683d9c0/attachment-0001.htm>
More information about the QGIS-User
