[Qgis-user] Disable QGIS auto update
Frederik Mørup Jacobsen
HKfrmo at herlev.dk
Wed May 27 22:51:45 PDT 2026
Hi Régis.
Thanks for the answer.
I am the Intune administrator. We haven’t published the new version in our intune.
We have only assigned the old 3.40.10 version to our users, but that version is automatically updated to the new version 4.
Is it true that the application can’t update from within the problem?
If so, then I have another problem internally. 😊
BR
Frederik
Fra: QGIS-User <qgis-user-bounces at lists.osgeo.org> På vegne af Régis Haubourg via QGIS-User
Sendt: 27. maj 2026 15:58
Til: qgis-user at lists.osgeo.org
Emne: Re: [Qgis-user] Disable QGIS auto update
Hi Frederik,
this is something you have to deal with your Intune Administrator. 4.0 should be removed from your local portal, it is too early for production use.
From the QGIS.org side, we do not publish our pacakges to Microsoft stores.
Bien cordialement,
Régis Haubourg
On 27/05/2026 14:39, Frederik Mørup Jacobsen via QGIS-User wrote:
Hi.
We are using QGIS 3.40.10 with some special plugins.
We are not ready to update to version 4 now.
The application is rolled out via our Intune solution, but a lot of users are being auto updated to version 4.
Could you assist us with a guide to disable the auto update for all users via an Intune Policy?
Much appreciated.
BR
Frederik Jacobsen
Sådan behandler Herlev Kommune dine persondata
Når du henvender dig til Herlev Kommune, behandler vi oplysninger om dig i overensstemmelse med databeskyttelsesreglerne. Vi bruger dine oplysninger til at behandle og besvare din henvendelse, og vi sletter dine oplysninger efter arkivlovens regler. På Herlev.dk/persondata<https://www.herlev.dk/om-kommunen/rettigheder-og-svarfrister/databeskyttelse/> kan du læse mere om dine rettigheder, og om hvordan vi passer på dine oplysninger.
QGIS-User mailing list
QGIS-User at lists.osgeo.org<mailto:QGIS-User at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260528/e2ca579f/attachment.htm>
More information about the QGIS-User
