[Qgis-user] Question about accessing GIS files stored in Box directly from QGIS
篠田侑希 yuki.pck at gmail.com
Mon Nov 9 20:36:35 PST 2026
Hi Patrick,
Thank you very much for your reply.
I understand your point regarding the potential issues when multiple users
access files that are synchronized between local storage and cloud storage.
I apologize if my original question was unclear. I would like to clarify
that I am not referring to a locally synchronized cloud drive, such as
Google Drive for desktop or Box Drive.
What I would like to know is whether QGIS can directly access a GIS file
that is stored only in web-based cloud storage, using an HTTPS URL, without
downloading or synchronizing the file to the local PC first.
For example, if a GeoTIFF file is stored in Box and can be accessed or
downloaded through an HTTPS URL in a web browser, can QGIS use that URL
directly as a data source and open the GeoTIFF?
Google Drive or other web-based cloud storage services could be considered
similar examples, but our specific use case is Box.
At this stage, we are mainly trying to determine whether this type of
direct URL-based access is technically possible in QGIS, rather than
whether it is recommended for multi-user editing.
Thank you again for your help.
Best regards,
Yuki
2026年11月9日(月) 9:03 Patrick Dunford via QGIS-User <qgis-user at lists.osgeo.org
> Good day.
> It appears from your query you are wishing to have some form of access
> to local files which are synchronised to a cloud such as Google Drive.
> This may work well if there is only one user accessing the data but
> generally as is the case when using a local area network, there are
> likely to be significant problems if files are being shared between
> multiple users. Web drive synchronisation of local files is not a
> reliable substitution for client/server database management systems that
> are normally required for multi user access in complex data processing
> applications like Qgis.
> On 06/11/2026 18:20, 篠田侑希 via QGIS-User wrote:
> > Hello,
> > I am currently testing different ways of accessing GIS data in QGIS.
> > We are comparing the following storage locations:
> > ・Local folders
> > ・Cloud drives mounted or accessible from Windows Explorer
> > ・Web-based cloud storage such as Box
> > We would like to know whether GIS files stored in Box, such as
> > Shapefiles, GeoPackages, and GeoTIFF files, can be accessed directly
> > from QGIS using a Box URL, without downloading them to a local folder.
> > We have the following questions:
> > 1.Can QGIS directly access GIS files stored in Box using a shared URL
> > or download URL?
> > 2.If not, is there another supported method for accessing files stored
> > in Box from QGIS?
> > 3.Would using a desktop synchronization tool such as Box Drive be the
> > recommended approach?
> > 4.Are there any limitations or considerations regarding performance,
> > editing, or saving data when using cloud storage with QGIS?
> > Our goal is to determine whether a web-based cloud storage service
> > such as Box can be used as a practical data storage location for QGIS.
> > Thank you very much for your help.
> > Best regards,
> > Yuki
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261110/55e56207/attachment-0001.htm>
More information about the QGIS-User mailing list
