[Qgis-user] Question about accessing GIS files stored in Box directly from QGIS
Ujaval Gandhi
ujaval at spatialthoughts.com
Mon Nov 9 20:49:43 PST 2026
QGIS can access data from a HTTPS URL directly. You can specify a URL in the Data Source Manager --> Raster --> Protocol: HTTP(S), cloud etc. Ideally if you are streamling data from a cloud storage - you want to convert your data to a Cloud Optrimized GeoTIFF which will allow you to only stream the required pixels insteads instead of downloading the entire image. Here's a tutorial with the workflow https://courses.spatialthoughts.com/qgis-cloud-native-geospatial.html#load-a-cloud-optimized-geotiff-cog
Generally, this type of setup uses a cloud bob storage (Amazon S3, Google Cloud Storage, Azure etc.) and these are also well supported in QGIS. If you have your data on these cloud storage services, you can access private data using authentication options supported by GDAL. Since you asked for some info on GDAL access options, you can see my post on GDAL/GCS access patterns https://spatialthoughts.com/2024/02/26/gdal-google-cloud-storage/
Ujaval Gandhi
Spatial Thoughts
www.spatialthoughts.com
On Tue, Nov 10, 2026 at 10:08 AM 篠田侑希 via QGIS-User <qgis-user at lists.osgeo.org> wrote:
> Hi Brent,
> Thank you very much for your detailed explanation and recommendation regarding PostGIS.
> I understand that PostGIS would be a more appropriate solution for managing shared spatial data, particularly when multiple users need to access or edit the same datasets concurrently.
> I apologize if my original question was unclear. For our current test, we are looking at a slightly different use case.
> I am not referring to a locally synchronized cloud drive, such as Google Drive for desktop or Box Drive.
> What I would like to know is whether QGIS can directly access a GIS file that is stored only in web-based cloud storage, using an HTTPS URL, without downloading or synchronizing the file to the local PC first.
> For example, if a GeoTIFF file is stored in Box and can be accessed or downloaded through an HTTPS URL in a web browser, can QGIS use that URL directly as a data source and open the GeoTIFF?
> I understand that this approach may not be suitable for concurrent editing or multi-user data management. At this stage, however, we are mainly trying to determine whether this type of direct URL-based access is technically possible in QGIS.
> If it is possible, I would also appreciate any information about which QGIS/GDAL data source method or protocol should be used.
> Thank you again for your advice.
> Best regards,
> Yuki
> 2026年11月9日(月) 9:19 Brent Wood via QGIS-User <qgis-user at lists.osgeo.org>:
> > You are taking about shared spatial data access.
> > Spatial databases (notably Postgis) support this very well. You have fine grained control of access to datasets, a single system supporting and managing all the data (including robust ACID & PITR backups.
> > It can be set up on a cloud based, local hardware or VM/Docker approach as you see fit.
> > File based storage can introduce issues to shared data access that a well managed DB can easily resolve, especially wrt to concurrent editing/inserting by multiple users concurrently.
> > I strongly recommend you look at Postgis for managing all your vector data, and in some cases, raster data as well.
> > Brent Wood
> > On 06/11/2026 18:20, 篠田侑希 via QGIS-User wrote:
> > > Hello,
> > > I am currently testing different ways of accessing GIS data in QGIS.
> > > We are comparing the following storage locations:
> > > ・Local folders
> > > ・Cloud drives mounted or accessible from Windows Explorer
> > > ・Web-based cloud storage such as Box
> > > We would like to know whether GIS files stored in Box, such as
> > > Shapefiles, GeoPackages, and GeoTIFF files, can be accessed directly
> > > from QGIS using a Box URL, without downloading them to a local folder.
> > > We have the following questions:
> > > 1.Can QGIS directly access GIS files stored in Box using a shared URL
> > > or download URL?
> > > 2.If not, is there another supported method for accessing files stored
> > > in Box from QGIS?
> > > 3.Would using a desktop synchronization tool such as Box Drive be the
> > > recommended approach?
> > > 4.Are there any limitations or considerations regarding performance,
> > > editing, or saving data when using cloud storage with QGIS?
> > > Our goal is to determine whether a web-based cloud storage service
> > > such as Box can be used as a practical data storage location for QGIS.
> > > Thank you very much for your help.
> > > Best regards,
> > > Yuki
> > > _______________________________________________
> > > QGIS-User mailing list
> > > QGIS-User at lists.osgeo.org
> > > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Brent Wood
> > Principal Technician - GIS and Spatial Data Management
> > +64-4-386-0529
> > Earth Sciences New Zealand
> > 301 Evans Bay Parade, Greta Point, Hataitai, Wellington, New Zealand
> > The Institute of Geological and Nuclear Sciences Limited and the National Institute of Water and Atmospheric Research Limited joined to become the New Zealand Institute for Earth Science Limited. We are known as Earth Sciences New Zealand. For more information on the Earth Sciences transition click here.
> > Notice: This email and any attachments may contain information which is confidential and/or subject to copyright or legal privilege, and may not be used, published or redistributed without the prior written consent of Earth Sciences New Zealand. If you are not the intended recipient, please immediately notify the sender and delete the email and any attachments. Any opinion or views expressed in this email are those of the individual sender and may not represent those of Earth Sciences New Zealand.
> > For information about how we process data and monitor communications please see our privacy policy.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261110/545337a2/attachment.htm>
More information about the QGIS-User
