[Qgis-user] Question about accessing GIS files stored in Box directly from QGIS
篠田侑希 yuki.pck at gmail.com
Mon Nov 9 20:38:04 PST 2026
Hi Brent,
Thank you very much for your detailed explanation and recommendation
regarding PostGIS.
I understand that PostGIS would be a more appropriate solution for managing
shared spatial data, particularly when multiple users need to access or
edit the same datasets concurrently.
I apologize if my original question was unclear. For our current test, we
are looking at a slightly different use case.
I am not referring to a locally synchronized cloud drive, such as Google
Drive for desktop or Box Drive.
What I would like to know is whether QGIS can directly access a GIS file
that is stored only in web-based cloud storage, using an HTTPS URL, without
downloading or synchronizing the file to the local PC first.
For example, if a GeoTIFF file is stored in Box and can be accessed or
downloaded through an HTTPS URL in a web browser, can QGIS use that URL
directly as a data source and open the GeoTIFF?
I understand that this approach may not be suitable for concurrent editing
or multi-user data management. At this stage, however, we are mainly trying
to determine whether this type of direct URL-based access is technically
possible in QGIS.
If it is possible, I would also appreciate any information about which
QGIS/GDAL data source method or protocol should be used.
Thank you again for your advice.
Best regards,
Yuki
2026年11月9日(月) 9:19 Brent Wood via QGIS-User <qgis-user at lists.osgeo.org>:
> You are taking about shared spatial data access.
> Spatial databases (notably Postgis) support this very well. You have fine
> grained control of access to datasets, a single system supporting and
> managing all the data (including robust ACID & PITR backups.
> It can be set up on a cloud based, local hardware or VM/Docker approach as
> you see fit.
> File based storage can introduce issues to shared data access that a well
> managed DB can easily resolve, especially wrt to concurrent
> editing/inserting by multiple users concurrently.
> I strongly recommend you look at Postgis for managing all your vector
> data, and in some cases, raster data as well.
> Brent Wood
> On 06/11/2026 18:20, 篠田侑希 via QGIS-User wrote:
> > Hello,
> > I am currently testing different ways of accessing GIS data in QGIS.
> > We are comparing the following storage locations:
> > ・Local folders
> > ・Cloud drives mounted or accessible from Windows Explorer
> > ・Web-based cloud storage such as Box
> > We would like to know whether GIS files stored in Box, such as
> > Shapefiles, GeoPackages, and GeoTIFF files, can be accessed directly
> > from QGIS using a Box URL, without downloading them to a local folder.
> > We have the following questions:
> > 1.Can QGIS directly access GIS files stored in Box using a shared URL
> > or download URL?
> > 2.If not, is there another supported method for accessing files stored
> > in Box from QGIS?
> > 3.Would using a desktop synchronization tool such as Box Drive be the
> > recommended approach?
> > 4.Are there any limitations or considerations regarding performance,
> > editing, or saving data when using cloud storage with QGIS?
> > Our goal is to determine whether a web-based cloud storage service
> > such as Box can be used as a practical data storage location for QGIS.
> > Thank you very much for your help.
> > Best regards,
> > Yuki
> > QGIS-User mailing list
> > QGIS-User at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> *Brent Wood *
> Principal Technician - GIS and Spatial Data Management
> +64-4-386-0529 <+64%204%20386%200529>
> Earth Sciences New Zealand
> 301 Evans Bay Parade, Greta Point, Hataitai, Wellington, New Zealand
> [image: Earth Sciences New Zealand] <https://earthsciences.nz>
> The Institute of Geological and Nuclear Sciences Limited and the National
> Institute of Water and Atmospheric Research Limited joined to become the
> New Zealand Institute for Earth Science Limited. We are known as Earth
> Sciences New Zealand. For more information on the Earth Sciences transition click
> here <https://niwa.co.nz/about-niwa/science-sector-reforms>.
> *Notice:* This email and any attachments may contain information which is
> confidential and/or subject to copyright or legal privilege, and may not be
> used, published or redistributed without the prior written consent of Earth
> Sciences New Zealand. If you are not the intended recipient, please
> immediately notify the sender and delete the email and any attachments. Any
> opinion or views expressed in this email are those of the individual sender
> and may not represent those of Earth Sciences New Zealand.
> For information about how we process data and monitor communications
> please see our privacy policy <https://earthsciences.nz/privacy-policy>.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261110/157a911e/attachment.htm>
More information about the QGIS-User mailing list
