[Qgis-user] (no subject)
Byron Veilleux
byron at conjugategeo.com
Mon Nov 16 12:29:33 PST 2026
i have imported two DEM files into my project. one is a SRTM dem and the
other is a LIDAR ascii dataset. for both of these, i can display the data
and it seems to be correct spatially and with the appropriate elevation
values. if i display the DEM file and try to extract the elevation curve
in the elevation profile module, all i see is a single datapoint.
i also displayed the contours from this dataset and extract the profile.
in this instance, the extracted datapoints come in but the values are all
zero.
what am i doing wrong when trying to extract a profile from DEM data and/or
contours.
i also want to extract lines that intersect the profile if possible
(geologic map contacts along the profile). could you send me a link or
information with respect to how i might do that
Byron Veilleux, MSc. P.Geo
Conjugate Geologic Services Limited
Calgary, Alberta Canada
Cell:4037108414
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/1778ac8c/attachment.htm>
More information about the QGIS-User
