[Qgis-user] (no subject)
chris hermansen
clhermansen at gmail.com
Mon Nov 16 12:31:36 PST 2026
Byron and list,
On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User <
qgis-user at lists.osgeo.org> wrote:
> i have imported two DEM files into my project. one is a SRTM dem and the
> other is a LIDAR ascii dataset. for both of these, i can display the data
> and it seems to be correct spatially and with the appropriate elevation
> values. if i display the DEM file and try to extract the elevation curve
> in the elevation profile module, all i see is a single datapoint.
> i also displayed the contours from this dataset and extract the profile.
> in this instance, the extracted datapoints come in but the values are all
> zero.
> what am i doing wrong when trying to extract a profile from DEM data
> and/or contours.
> i also want to extract lines that intersect the profile if possible
> (geologic map contacts along the profile). could you send me a link or
> information with respect to how i might do that
What projections are your two DEM files in?
Chris Hermansen · clhermansen "at" gmail "dot" com
C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/c5ecf09d/attachment-0001.htm>
More information about the QGIS-User
