[Qgis-user] (no subject)
Byron Veilleux
byron at conjugategeo.com
Mon Nov 16 12:37:08 PST 2026
NAD83 UTM zone 12
On Mon, Nov 16, 2026 at 1:31 PM chris hermansen <clhermansen at gmail.com>
wrote:
> Byron and list,
> On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> i have imported two DEM files into my project. one is a SRTM dem and the
>> other is a LIDAR ascii dataset. for both of these, i can display the data
>> and it seems to be correct spatially and with the appropriate elevation
>> values. if i display the DEM file and try to extract the elevation curve
>> in the elevation profile module, all i see is a single datapoint.
>> i also displayed the contours from this dataset and extract the profile.
>> in this instance, the extracted datapoints come in but the values are all
>> zero.
>> what am i doing wrong when trying to extract a profile from DEM data
>> and/or contours.
>> i also want to extract lines that intersect the profile if possible
>> (geologic map contacts along the profile). could you send me a link or
>> information with respect to how i might do that
> What projections are your two DEM files in?
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/84d5835a/attachment.htm>
More information about the QGIS-User
