[Qgis-user] (no subject)
Vladimir Vukovic vukovicvl at fiberq.net
Mon Nov 16 12:37:27 PST 2026
Hi Byron,
I would first check the elevation settings for both raster layers.
Right-click the DEM - Properties - Elevation and make sure "Represents
Elevation Surface" is selected with the correct raster band. Also check
that the profile line crosses valid raster data and not NoData cells.
For the contours, if your elevation values are stored in an attribute
field rather than Z coordinates. Go to Layer Properties - Elevation and
use that field as the base height. That could explain why you're getting
zero values.
For geological contacts, you can add your line layer to the Elevation
Profile and set it to "Clamped to terrain" in the layer's elevation
properties.
If you need actual intersection points, you can use the "Line
intersections" processing tool and then sample elevation values from the
DEM.
Let us know if you fixed with this method.
Best regards,
Vladimir
On 11/16/26 21:31, chris hermansen via QGIS-User wrote:
> Byron and list,
> On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User
> <qgis-user at lists.osgeo.org> wrote:
>     i have imported two DEM files into my project.  one is a SRTM dem
>     and the other is a LIDAR ascii dataset. for both of these, i can
>     display the data and it seems to be correct spatially and
>     with the appropriate elevation values.   if i display the DEM file
>     and try to extract the elevation curve in the elevation profile
>     module, all i see is a single datapoint.
>     i also displayed the contours from this dataset and extract the
>     profile.  in this instance, the extracted datapoints come in but
>     the values are all zero.
>     what am i doing wrong when trying to extract a profile from DEM
>     data and/or contours.
>     i also want to extract lines that intersect the profile if
>     possible (geologic map contacts along the profile).  could you
>     send me a link or information with respect to how i might do that
> What projections are your two DEM files in?
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
Best regards,
Vladimir Vuković
Founder, FiberQ
+381 60 426 2012 <tel:+381604262012>
FiberQ <https://www.fiberq.net/>  · open-source FTTH/GPON design plugin
for QGIS
FiberQ Designer <https://fiberq.app/>  · fiber network design in the
browser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/683485e1/attachment.htm>
More information about the QGIS-User mailing list
