[Qgis-user] (no subject)
Byron Veilleux byron at conjugategeo.com
Mon Nov 16 12:49:57 PST 2026
thank you vladimir, the elevations settings worked for the profile to
capture the elevations
i am still not clear for my contacts.  they have not been projected onto
the DEM, so how do I
A) apply elevation model to my line data on the map to give them a z value
B) capture the intersecting line data on my profile?
On Mon, Nov 16, 2026 at 1:37 PM Vladimir Vukovic <vukovicvl at fiberq.net>
wrote:
> Hi Byron,
> I would first check the elevation settings for both raster layers.
> Right-click the DEM - Properties - Elevation and make sure "Represents
> Elevation Surface" is selected with the correct raster band. Also check
> that the profile line crosses valid raster data and not NoData cells.
> For the contours, if your elevation values are stored in an attribute
> field rather than Z coordinates. Go to Layer Properties - Elevation and use
> that field as the base height. That could explain why you're getting zero
> values.
> For geological contacts, you can add your line layer to the Elevation
> Profile and set it to "Clamped to terrain" in the layer's elevation
> properties.
> If you need actual intersection points, you can use the "Line
> intersections" processing tool and then sample elevation values from the
> DEM.
> Let us know if you fixed with this method.
> Best regards,
> Vladimir
> On 11/16/26 21:31, chris hermansen via QGIS-User wrote:
> Byron and list,
> On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User <
> qgis-user at lists.osgeo.org> wrote:
>> i have imported two DEM files into my project.  one is a SRTM dem and the
>> other is a LIDAR ascii dataset.  for both of these, i can display the data
>> and it seems to be correct spatially and with the appropriate elevation
>> values.   if i display the DEM file and try to extract the elevation curve
>> in the elevation profile module, all i see is a single datapoint.
>> i also displayed the contours from this dataset and extract the profile.
>> in this instance, the extracted datapoints come in but the values are all
>> zero.
>> what am i doing wrong when trying to extract a profile from DEM data
>> and/or contours.
>> i also want to extract lines that intersect the profile if possible
>> (geologic map contacts along the profile).  could you send me a link or
>> information with respect to how i might do that
> What projections are your two DEM files in?
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> QGIS-User mailing listQGIS-User at lists.osgeo.org
> Best regards,
> Vladimir Vuković
> Founder, FiberQ
> +381 60 426 2012 <+381604262012>
> FiberQ <https://www.fiberq.net/>  · open-source FTTH/GPON design plugin
> for QGIS
> FiberQ Designer <https://fiberq.app/>  · fiber network design in the
> browser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/1e084d6b/attachment.htm>
More information about the QGIS-User mailing list
