[Qgis-user] (no subject)
Vladimir Vukovic vukovicvl at fiberq.net
Mon Nov 16 13:00:53 PST 2026
A) To assign Z values to your contact lines, use Processing Toolbox -
Drape (set Z value from raster), selecting your DEM as the elevation
source. You may want to densify the lines first for better accuracy.
B) You dont actually need Z values to display the contacts in the
profile. Go to Project - Properties - Elevationand set your DEM as
terrain. Then, under your contact layer's Properties - Elevation, select
Clamped to terrainand Individual features.
On 11/16/26 21:49, Byron Veilleux wrote:
> thank you vladimir, the elevations settings worked for the profile to
> capture the elevations
> i am still not clear for my contacts.  they have not been projected
> onto the DEM, so how do I
> A) apply elevation model to my line data on the map to give them a z value
> B) capture the intersecting line data on my profile?
> On Mon, Nov 16, 2026 at 1:37 PM Vladimir Vukovic
> <vukovicvl at fiberq.net> wrote:
>     Hi Byron,
>     I would first check the elevation settings for both raster layers.
>     Right-click the DEM - Properties - Elevation and make sure
>     "Represents Elevation Surface" is selected with the correct raster
>     band. Also check that the profile line crosses valid raster data
>     and not NoData cells.
>     For the contours, if your elevation values are stored in an
>     attribute field rather than Z coordinates. Go to Layer Properties
>     - Elevation and use that field as the base height. That could
>     explain why you're getting zero values.
>     For geological contacts, you can add your line layer to the
>     Elevation Profile and set it to "Clamped to terrain" in the
>     layer's elevation properties.
>     If you need actual intersection points, you can use the "Line
>     intersections" processing tool and then sample elevation values
>     from the DEM.
>     Let us know if you fixed with this method.
>     Best regards,
>     Vladimir
>     On 11/16/26 21:31, chris hermansen via QGIS-User wrote:
>>     Byron and list,
>>     On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User
>>     <qgis-user at lists.osgeo.org> wrote:
>>         i have imported two DEM files into my project.  one is a SRTM
>>         dem and the other is a LIDAR ascii dataset.  for both of
>>         these, i can display the data and it seems to be correct
>>         spatially and with the appropriate elevation values.   if i
>>         display the DEM file and try to extract the elevation curve
>>         in the elevation profile module, all i see is a single
>>         datapoint.
>>         i also displayed the contours from this dataset and extract
>>         the profile.  in this instance, the extracted datapoints come
>>         in but the values are all zero.
>>         what am i doing wrong when trying to extract a profile from
>>         DEM data and/or contours.
>>         i also want to extract lines that intersect the profile if
>>         possible (geologic map contacts along the profile).
>>         could you send me a link or information with respect to how i
>>         might do that
>>     What projections are your two DEM files in?
>>     Chris Hermansen · clhermansen "at" gmail "dot" com
>>     C'est ma façon de parler.
>>     _______________________________________________
>>     QGIS-User mailing list
>>     QGIS-User at lists.osgeo.org
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Best regards,
>     Vladimir Vuković
>     Founder, FiberQ
>     +381 60 426 2012 <tel:+381604262012>
>     FiberQ <https://www.fiberq.net/>  · open-source FTTH/GPON design
>     plugin for QGIS
>     FiberQ Designer <https://fiberq.app/>  · fiber network design in
>     the browser
Best regards,
Vladimir Vuković
Founder, FiberQ
FiberQ <https://www.fiberq.net/>  · open-source FTTH/GPON design plugin
for QGIS
FiberQ Designer <https://fiberq.app/>  · fiber network design in the
browser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/7e21547a/attachment.htm>
More information about the QGIS-User mailing list
