[Qgis-user] (no subject)
Byron Veilleux
byron at conjugategeo.com
Mon Nov 16 13:04:17 PST 2026
Thank you for your help!
On Mon, Nov 16, 2026 at 3:01 PM Vladimir Vukovic <vukovicvl at fiberq.net>
wrote:
> A) To assign Z values to your contact lines, use Processing Toolbox -
> Drape (set Z value from raster), selecting your DEM as the elevation
> source. You may want to densify the lines first for better accuracy.
> B) You dont actually need Z values to display the contacts in the profile.
> Go to Project - Properties - Elevation and set your DEM as terrain. Then,
> under your contact layer's Properties - Elevation, select Clamped to
> terrain and Individual features.
> On 11/16/26 21:49, Byron Veilleux wrote:
> thank you vladimir, the elevations settings worked for the profile to
> capture the elevations
> i am still not clear for my contacts. they have not been projected onto
> the DEM, so how do I
> A) apply elevation model to my line data on the map to give them a z value
> B) capture the intersecting line data on my profile?
> On Mon, Nov 16, 2026 at 1:37 PM Vladimir Vukovic <vukovicvl at fiberq.net>
> wrote:
>> Hi Byron,
>> I would first check the elevation settings for both raster layers.
>> Right-click the DEM - Properties - Elevation and make sure "Represents
>> Elevation Surface" is selected with the correct raster band. Also check
>> that the profile line crosses valid raster data and not NoData cells.
>> For the contours, if your elevation values are stored in an attribute
>> field rather than Z coordinates. Go to Layer Properties - Elevation and use
>> that field as the base height. That could explain why you're getting zero
>> values.
>> For geological contacts, you can add your line layer to the Elevation
>> Profile and set it to "Clamped to terrain" in the layer's elevation
>> properties.
>> If you need actual intersection points, you can use the "Line
>> intersections" processing tool and then sample elevation values from the
>> DEM.
>> Let us know if you fixed with this method.
>> Best regards,
>> Vladimir
>> On 11/16/26 21:31, chris hermansen via QGIS-User wrote:
>> Byron and list,
>> On Mon, Nov 16, 2026 at 1:30 PM Byron Veilleux via QGIS-User <
>> qgis-user at lists.osgeo.org> wrote:
>>> i have imported two DEM files into my project. one is a SRTM dem and
>>> the other is a LIDAR ascii dataset. for both of these, i can display the
>>> data and it seems to be correct spatially and with the appropriate
>>> elevation values. if i display the DEM file and try to extract the
>>> elevation curve in the elevation profile module, all i see is a single
>>> datapoint.
>>> i also displayed the contours from this dataset and extract the
>>> profile. in this instance, the extracted datapoints come in but the values
>>> are all zero.
>>> what am i doing wrong when trying to extract a profile from DEM data
>>> and/or contours.
>>> i also want to extract lines that intersect the profile if possible
>>> (geologic map contacts along the profile). could you send me a link or
>>> information with respect to how i might do that
>> What projections are your two DEM files in?
>> Chris Hermansen · clhermansen "at" gmail "dot" com
>> C'est ma façon de parler.
>> QGIS-User mailing listQGIS-User at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Best regards,
>> Vladimir Vuković
>> Founder, FiberQ
>> +381 60 426 2012 <+381604262012>
>> FiberQ <https://www.fiberq.net/> · open-source FTTH/GPON design plugin
>> for QGIS
>> FiberQ Designer <https://fiberq.app/> · fiber network design in the
>> browser
> Best regards,
> Vladimir Vuković
> Founder, FiberQ
> for QGIS
> browser
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20261116/46839834/attachment-0001.htm>
More information about the QGIS-User
