[Qgis-user] Duvidas sobre o Plugin
Andrea Giudiceandrea
andreaerdna at libero.it
Tue Sep 1 04:43:02 PDT 2026
> Valdemiro Silva valdemiro.costa at sgb.gov.br
> Mon Aug 31 10:30:45 PDT 2026
> E já está instalado o plugin "Channel Network and Drainage Basins".
Hi Valdemiro,
as far as I know, "Channel Network and Drainage Basins" is not a plugin:
it is a processing algorithm of the SAGA-GIS processing provider? Do you
confirm?
If it is the case, then you need to install both the SAGA-GIS software
(if not already installed) and the "Processing Saga NextGen Provider"
plugin.
Unfortunately, the "Processing Saga NextGen Provider" plugin is no
longer available in the official QGIS plugin server.
Anyway, you could still install the latest version of such plugin that
was publicly available, using the zip file named
processing_saga_nextgen-1.1.0.zip
that is available at
https://github.com/agiudiceandrea/qgis-processing-saga-nextgen/releases/tag/1.1.0
Best regards.
More information about the QGIS-User
