[Qgis-user] Technical help needed
chris hermansen
clhermansen at gmail.com
Wed Sep 2 05:27:21 PDT 2026
I see a considerable number of references that turn up on a search for
"Kriging safe bearing capacity"; for example this
https://link.springer.com/article/10.1007/s12665-021-09971-2
Looking in the other direction "qgis kriging interpolation", lots of
references about how to perform kriging, for example this course
https://giscourse.online/kriging-in-qgis-ultimate-guide/
As always it's most important to recognize that this is interpolation,
which requires assumptions of the nature of the distribution of properties
of the physical material being analyzed; which a decently suspicious
engineer should consider as "unfounded" unless they have evidence to the
contrary.
On Wed, Sep 2, 2026, 01:41 kirk via QGIS-User <qgis-user at lists.osgeo.org>
wrote:
> Hi All.
> This sounds like a simple use of rasters which would consist of
> interpreted layers from the point locations. In your case, with negative
> values for depth if you use the existing surface of the earth as the zero
> level. You could also use height above the ellipsisoid to have positive
> values.
> By introducing a stack of rasters, values for each depth, you can read
> the value from a x, y coordinate from the raster that matches the depth you
> are interested in.
> Another thought iscthat a 3D raster would contain 3D blocks which are
> called voxels. I am uncertain how QGIS handles them, but perhaps someone
> on the list can comment.
> Kirk Schmidt
> Sent from my Galaxy
> -------- Original message --------
> From: jmraut--- via QGIS-User <qgis-user at lists.osgeo.org>
> Date: 2026-09-01 8:22 a.m. (GMT-04:00)
> To: "Odom, Johnnie via QGIS-User" <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Technical help needed
> QGIS Development Team,
> Greetings from Yeshwantrao Chavan College of Engineering (YCCE), Nagpur.
> We are a group of Civil Engineering students currently working on our
> minor project using QGIS. First of all, we would like to thank your team
> for developing such a powerful and open-source GIS platform. It has been a
> great learning experience for us.
> Our project focuses on estimating SBC using geospatial data. At present,
> QGIS is excellent for analyzing and visualizing data on the ground surface.
> However, we are trying to work with subsurface soil information, where the
> Safe Bearing Capacity values are obtained from boreholes or soil
> investigation reports.
> Our idea is to store SBC values at different borehole locations in QGIS at
> different depths. For example, if SBC values are available at Points A, B,
> C, D, and E, we want to develop a feature that allows a user to click on
> any location between these points and receive an estimated SBC value based
> on nearby borehole data using interpolation or other suitable methods.
> While exploring different tools and plugins in QGIS, we found that the
> current workflow does not fully support this type of subsurface analysis in
> the way we require. Therefore, we are reaching out to your team for
> guidance and possible collaboration.
> Our long-term vision is to develop a QGIS-based solution integrated with
> Machine Learning, where users can simply select a land location and obtain
> an estimated Safe Bearing Capacity instantly. Such a tool could be useful
> for civil engineers, architects, students, and planners during the initial
> stages of project planning, reducing both time and cost.
> We would be grateful if your team could guide us regarding:
> - The best approach to implement this feature in QGIS.
> - Existing tools, plugins, or APIs that may help.
> - The possibility of contributing to QGIS through this project.
> - Any opportunity to collaborate with your development community.
> We believe this project has the potential to become a useful addition to
> the QGIS ecosystem and could benefit many users involved in geotechnical
> and civil engineering applications.
> We also are planning to submit Research funding proposal to DST or ANRF
> for that planning to collaborate with you.
> *To discuss the above matter in detail, it would be very helpful if we
> could meet with you personally at your office. Kindly share your office
> address along with a convenient date and time for the meeting so that we
> can discuss the issue comprehensively.*
> We look forward to your response.
> Thank you for your valuable time and consideration. We would be honored to
> receive your guidance and look forward to your response.
> Sincerely,
> Dr. J.M.Raut (Faculty) , Dr.P.B.Pande (Faculty) , Laxmikant Niburkar
> (student)
> M-9765568765
> Assistant Professor
> Civil Engineering ,Yashwantrao Chavan College of Engineering (YCCE)
> Nagpur, Maharashtra, India
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260902/ec243f46/attachment-0001.htm>
More information about the QGIS-User
