[Qgis-user] Question regarding QGIS and Microsoft ASR rule "Block use of copied or impersonated system tools"
Gert-Jan van der Weijden - GISNederland gert-jan at gisnederland.nl
Tue Sep 1 12:59:18 PDT 2026
Interesting question!
Searching the Qgis source code in Github on "curl" I found one reference
to "curl", in "qgsnetworkloggernode.cpp"
See for yourself at
"https://github.com/search?q=repo%3Aqgis%2FQGIS+curl&type=code"
I guess this is triggered when you use the debugging/development tools
panel (in the menu under "view"->"panels")
Could that be the ASR-trigger for curl.exe?
Can't find references to Powershell(.exe), so that surprises me.
Just to make sure: are you using a "clean" QGis, or do you have some
plugins installed?
Kind regards,
Gert-Jan
On 9/1/2026 15:23, Sondre Een Kvalfoss via QGIS-User wrote:
> Hello,
> We have recently enabled a new Microsoft Defender Attack Surface
> Reduction (ASR) rule in our environment called *"Block use of copied
> or impersonated system tools"*, currently running in *Audit mode*.
> During our review of the audit logs, we have observed events involving
> *curl.exe* and the source application *powershell.exe*, where the
> common factor appears to be the following QGIS installation path:
> C:\Program Files\QGIS 4.2.1\bin
> Before enabling this ASR rule in *Block mode*, we would appreciate
> your help in understanding what is triggering these events and how
> QGIS uses these components. Our goal is to determine whether this
> behavior is expected and whether it would be appropriate to create an
> exclusion for QGIS if necessary.
> Could you please provide any details on the processes or functionality
> within QGIS that may invoke curl.exe and/or powershell.exe from this
> location?
> Thank you for your assistance. Please include me in the reply if possible.
> Kind regards,
> Sondre Een Kvalfoss
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20260901/a33171d3/attachment.htm>
More information about the QGIS-User mailing list
