[Qgis-user] Question regarding QGIS and Microsoft ASR rule "Block use of copied or impersonated system tools"
Andrea Giudiceandrea andreaerdna at libero.it
Tue Sep 1 14:49:28 PDT 2026
Hi Gert-Jan,
AFAIK, QGIS itself doesn't execute either curl.exe or powershell.exe.
The code in qgsnetworkloggernode.cpp only copies the text string of a
CLI command in the system clipboard. Such command is not automatically
executed by QGIS: it can be manually pasted in a CLI shell by the user
in order to be manually executed be the user.
Please read https://github.com/qgis/QGIS/issues/64160 and particularly
https://github.com/qgis/QGIS/issues/64160#issuecomment-4874695133.
Regards.
Andrea
> Gert-Jan van der Weijden - GISNederland gert-jan at gisnederland.nl
> Tue Sep 1 12:59:18 PDT 2026
> Searching the Qgis source code in Github on "curl" I found one reference
> to "curl", in "qgsnetworkloggernode.cpp"
> See for yourself at
> "https://github.com/search?q=repo%3Aqgis%2FQGIS+curl&type=code"
> I guess this is triggered when you use the debugging/development tools
> panel (in the menu under "view"->"panels")
> Could that be the ASR-trigger for curl.exe?
More information about the QGIS-User mailing list
