[Qgis-user] Projection data
Andrea Giudiceandrea
andreaerdna at libero.it
Wed Sep 2 20:47:11 PDT 2026
Hi Grant,
I'm not sure to correctly understand your question.
What do you mean exactly with "world projection information"? If you are
referring to the CRSs definitions database, then it is always available
in QGIS.
The installation instructions just say that the datum transformation
grid-shift files (of about 760 MB) are automatically installed when you
install the *-full-grids meta packages (e.g. qgis-full-grids or
qgis-ltr-full-grids packages) and that they are not automatically
installed when you install the *-full or *-full-free meta packages.
How exactly do you install QGIS using the OSGeo4W Network installer? Do
you use the Express install mode or the "Advanced" install mode?
Anyway, whatever qgis package have you installed, you can also add such
grid files just installing the proj-data package.
Regards.
Andrea
> Grant Boxer boxerg at iinet.net.au
> Wed Sep 2 17:35:26 PDT 2026
> Does this mean that not all the world
> projection information is downloaded on install?
More information about the QGIS-User
