[Qgis-user] Enable snapping by default vs. Project Snapping Settings
Richard Duivenvoorde rdmailings at duif.net
Thu Sep 3 00:10:55 PDT 2026
Hi Sylvia,
I do not have an answer for you, but best is to create a thorough reproducible use-case and then create a Github issue for it.
Something like:
- always start with a new profile in the latest QGIS version (<= did you try this yourself?)
- do this
- do that
- see the problem
Then dev's and others can just follow your steps and either confirm of falsify it. Once others have confirmed the problem there is a higher chance it is picked up by developers.
Regards & sorry for not having a proper answer..
On 9/3/26 07:43, Preuß, Sylvia via QGIS-User wrote:
> Hello,
> Quick *question about how* snapping mode works. I’ve enabled it in two different places, but the *"Enable snapping by default" setting* doesn't seem to do anything. *Toggling it on or off makes no difference*, so I'm forced to use *"Project Snapping Settings"* every time.
> Is anyone else experiencing this, or am I *doing* something wrong?
> Thank you.
> Mit freundlichem Gruß
> Im Auftrag
> gez.
> Sylvia Preuß
> email_obk Kopie
> Amt für Geoinformation und Liegenschaftskataster
> Abteilung Geoinformation
> Fritz-Kotz-Straße 17 a
> 51674 Wiehl
> Telefon: 02261 88-6252
> Fax: 02261 88-972-6252
> E-Mail: sylvia.preuss at obk.de <mailto:sylvia.preuss at obk.de>
> Titel: Zur Website - Beschreibung: OBK Zinne <https://www.obk.de/>Titel: facebook OBK - Beschreibung: facebook Logo <https://www.obk.de/facebook>Titel: Instagram OBK - Beschreibung: Instagram Logo <https://www.obk.de/instagram>Titel: YouTube OBK - Beschreibung: YouTube Logo <https://www.obk.de/youtube>
> <https://www.geodäsie.nrw/>
> Nachwuchsinitiative geodäsie.nrw unter:
> *geodaesie.nrw<https://geodäsie.nrw/>*__
> *Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken!*
> Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der dienstlichen Kommunikation.
> Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des Oberbergischen Kreises.*
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere Funktionsträger gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail ohne Authentifizierung und Verschlüsselung unsicher ist, da für unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und Manipulation besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen wird, die infolge etwaiger Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten, sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
> QGIS-User mailing list
> QGIS-User at lists.osgeo.org
More information about the QGIS-User mailing list
