[Qgis-user] Enable snapping by default vs. Project Snapping Settings
Andrea Giudiceandrea
andreaerdna at libero.it
Thu Sep 3 00:53:25 PDT 2026
> Preuß, Sylvia Sylvia.Preuss at obk.de
> Wed Sep 2 22:43:14 PDT 2026
> the "Enable snapping by default" setting doesn't seem to do anything. Toggling it on or off makes no difference
Hi Sylvia,
if you set "Enable snapping by default" option in Settings->Options->Map
Tools->Digitizing for your QGIS user profile, then the snapping will be
enabled by default on all new projects that you create using your QGIS
user profile.
Doesn't it work that way on your system? What QGIS version are you using
exactly?
Regards.
More information about the QGIS-User
