[Qgis-user] Recovering corrupted qgz and qgs file
Andrea Giudiceandrea andreaerdna at libero.it
Sat Sep 26 09:57:28 PDT 2026
Hi Eric,
first of all I would suggest you to try if the issue occurs also using a
new QGIS user profile without any external third-party plugin installed.
If it still occurs, you could check if the issue actually doesn't occur
running QGIS 3.44.13 just downloading its installer from
https://qgis.org/downloads-list/#macos/ltr as already suggested by Nigel
Berjak in a previous message.
Does the issue occurs opening any QGIS project or only that one QGIS
project?
Have you also tried to create and save a new QGIS project from scratch?
What happens opening such project?
If nothing works, I would suggest you to report the issue at
https://github.com/qgis/QGIS/issues provided all the requested info and
all the needed file (QGIS project and layers) in order to reproduce the
issue.
Best regards.
Andrea
> Fielding, Eric J (US 321G) eric.j.fielding at jpl.nasa.gov
> Fri Sep 25 10:18:32 PDT 2026
> I tried to open the project file and the app immediately crashes.
More information about the QGIS-User mailing list
