[QGIS-ZA-user] links between nodes as feature lines,	data from CSV files
    Barnett, Kevin
    Kevin.Barnett at bigenafrica.com
    Fri Aug 11 00:55:47 PDT 2017
Hello,
The attached COORD columns are all in SID:2053 (metres) I can easily import the MANHOLEDATA and display as nodes:
COORD1 column =X, COORD2 column = Y
But how do I create line features using the PIPEDATA txt(csv)?
PIPEDATA has two node columns: "Upstream_MH","Downstream_MH"
A line feature is needed between those nodes, the coordinates provided by MANHOLEDATA.
Start of line, PIPEDATA: Upstream_MH = MANHOLEDATA: Manhole_No
End of line, PIPEDATA: Downstream_MH = MANHOLEDATA: Manhole_No
Note:
Even though the PIPEDATA includes COORD columns, these need to be ignored - only use the node positions provided by MANHOLEDATA.
Thanks for reading and helping,
Kevin.
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
This email has been scanned for viruses and malware, and may have been automatically archived by Mimecast Ltd, an innovator in Software as a Service (SaaS) for business. Providing a safer and more useful place for your human generated data. Specializing in; Security, archiving and compliance. To find out more visit the Mimecast website.
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170811/ff90a350/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170811/ff90a350/attachment.txt>
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170811/ff90a350/attachment-0001.txt>
More information about the qgis-za-user
