[QGIS-ZA-user] links between nodes as feature lines, data from CSV files
Frank Sokolic
sokolic at worldonline.co.za
Fri Aug 11 02:25:18 PDT 2017
Hi Kevin,
Just off the top of my head, maybe you could try the Points to Path tool
in the processing toolbox. You'd first have to create point features for
the PIPEDATA and then run them through the Points to Path tool using the
PIPE_ID as the group field.
Regards, Frank.
On 11/08/2017 09:55, Barnett, Kevin via qgis-za-user wrote:
> Hello,
> The attached COORD columns are all in SID:2053 (metres) I can easily
> import the MANHOLEDATA and display as nodes:
> COORD1 column =X, COORD2 column = Y
> But how do I create line features using the PIPEDATA txt(csv)?
> PIPEDATA has two node columns: "Upstream_MH","Downstream_MH"
> A line feature is needed between those nodes, the coordinates provided
> by MANHOLEDATA.
> Start of line, PIPEDATA: Upstream_MH = MANHOLEDATA: Manhole_No
> End of line, PIPEDATA: Downstream_MH = MANHOLEDATA: Manhole_No
> Note:
> Even though the PIPEDATA includes COORD columns, these need to be
> ignored - only use the node positions provided by MANHOLEDATA.
> Thanks for reading and helping,
> Kevin.
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> prohibited and may be unlawful.
> This email has been scanned for viruses and malware, and may have been
> automatically archived by *Mimecast Ltd*, an innovator in Software as
> a Service (SaaS) for business. Providing a *safer* and *more useful*
> place for your human generated data. Specializing in; Security,
> archiving and compliance. To find out more Click Here
> <http://www.mimecast.com/products/>.
> qgis-za-user mailing list
> qgis-za-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170811/844b337f/attachment.html>
More information about the qgis-za-user
