[QGIS-ZA-user] links between nodes as feature lines, data from CSV files
Frank Sokolic
sokolic at worldonline.co.za
Fri Aug 11 06:49:11 PDT 2017
Glad you've got it working.
Frank.
On 11/08/2017 13:13, Barnett, Kevin wrote:
> Just tested … it worked … Thank You
> *From:*Barnett, Kevin
> *Sent:* Friday, 11 August 2017 12:26 PM
> *To:* 'sokolic at worldonline.co.za' <sokolic at worldonline.co.za>
> *Subject:* RE: [QGIS-ZA-user] links between nodes as feature lines,
> data from CSV files
> Thanks Frank, lengthy gooooogling results in the same recommended
> solution; I was hoping for a “quick fix” … this is the button you need
> right here; oh well … makes sense… thx again.
> *From:*Frank Sokolic [mailto:sokolic at worldonline.co.za]
> *Sent:* Friday, 11 August 2017 11:25 AM
> *To:* South Africa QGIS user group <qgis-za-user at lists.osgeo.org>
> *Cc:* Barnett, Kevin <Kevin.Barnett at bigenafrica.com>
> *Subject:* Re: [QGIS-ZA-user] links between nodes as feature lines,
> data from CSV files
> Hi Kevin,
> Just off the top of my head, maybe you could try the Points to Path
> tool in the processing toolbox. You'd first have to create point
> features for the PIPEDATA and then run them through the Points to Path
> tool using the PIPE_ID as the group field.
> Regards, Frank.
> On 11/08/2017 09:55, Barnett, Kevin via qgis-za-user wrote:
> Hello,
> The attached COORD columns are all in SID:2053 (metres) I can
> easily import the MANHOLEDATA and display as nodes:
> COORD1 column =X, COORD2 column = Y
> But how do I create line features using the PIPEDATA txt(csv)?
> PIPEDATA has two node columns: "Upstream_MH","Downstream_MH"
> A line feature is needed between those nodes, the coordinates
> provided by MANHOLEDATA.
> Start of line, PIPEDATA: Upstream_MH = MANHOLEDATA: Manhole_No
> End of line, PIPEDATA: Downstream_MH = MANHOLEDATA: Manhole_No
> Note:
> Even though the PIPEDATA includes COORD columns, these need to be
> ignored - only use the node positions provided by MANHOLEDATA.
> Thanks for reading and helping,
> Kevin.
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and
> others authorized to receive it. If you are not the recipient, you
> are hereby notified that any disclosure, copying, distribution or
> taking action in relation of the contents of this information is
> strictly prohibited and may be unlawful.
> This email has been scanned for viruses and malware, and may have
> been automatically archived by *Mimecast Ltd*, an innovator in
> Software as a Service (SaaS) for business. Providing a *safer* and
> *more useful* place for your human generated data. Specializing
> in; Security, archiving and compliance. To find out more Click
> Here <http://www.mimecast.com/products/>.
> qgis-za-user mailing list
> qgis-za-user at lists.osgeo.org <mailto:qgis-za-user at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/qgis-za-user
> *Disclaimer*
> others authorized to receive it. If you are not the recipient, you are
> hereby notified that any disclosure, copying, distribution or taking
> action in relation of the contents of this information is strictly
> This email has been scanned for viruses and malware, and may have been
> automatically archived by *Mimecast Ltd*, an innovator in Software as
> a Service (SaaS) for business. Providing a *safer* and *more useful*
> place for your human generated data. Specializing in; Security,
> archiving and compliance. To find out more Click Here
URL: <http://lists.osgeo.org/pipermail/qgis-za-user/attachments/20170811/ffe62f82/attachment-0001.html>
More information about the qgis-za-user
